Wireless
8721 Discussions
Intel Centrino 6300 AGN :: Windows 10 high latency / connection loss
TSull2
I have been running Windows 10 for some time now, and performed a fresh installation on July 29th, 2015 when the RTM version was released. On a regular basis, I am getting disconnected from different wireless networks, and when I perform certain network operations (eg. browsing to web page), the latency on my NIC will spike significantly. This is a recurring problem on different networks, and it is only exhibited by this device. My Android devices don't seem to have the same latency and connection drops that my Intel Centrino Ultimate 6300 AGN NIC has.
Any thoughts on how to resolve this, or investigate it further?
I'm running driver version 15.16.0.2 with driver date 1/16/2015.
Cheers,
Trevor Sullivan
Microsoft MVP: PowerShell
http://trevorsullivan.net/ http://trevorsullivan.net
http://twitter.com/pcgeek86 http://twitter.com/pcgeek86
ASouz7
Hello Trevor-Sullivan,
Windows*10 provides its own inbox driver for the Intel® Centrino® Ultimate-N 6300. For the time being, Intel does not provide support for this adapter using this version of the OS. We recommend that you contact your computer manufacturer to see if they have any updates that might resolve this issue. On our best effort to help you, you may try the following:
1 - Download the Windows*8-compliant drivers: https://downloadcenter.intel.com/download/22741 Intel® PROSet/Wireless Software and Drivers for Windows 8*
2 - Go to Control Panel, Programs and Features and Uninstall "Intel® PROSet/Wireless Software", if it is installed. When prompted, choose the option to "Discard settings".
3 - Reboot the PC or scan for hardware changes, check device manager and if an older driver is detected and installed, repeat the actions to uninstall and delete it as well.
4 - Repeat this process until the OS does not allow deleting the driver, or until the controller shows as Unknown Device.
5 - Once you have done this, proceed with the installation of the software from the link above.
TSull2
Hello aleki_intel,
Yes, Windows 10 has a built-in driver for the Intel Centrino Ultimate-N 6300. However, the driver seems to be having some significant problems on Windows 10. When will an Intel-supported update be released for this device? Installing a Windows 8 compatible driver doesn't sound like a good idea to me. Is this explicitly supported by Intel?
Cheers,
Trevor Sullivan
ASouz7
Trevor-Sullivan,
We would like to provide you a date but for the time being we have no information if there will ever be a driver update for Windows*10 on this adapter. The only available driver on our download center available is the one suggested above and yet there is no guarantee that it will work. We recommend that you use the inbox driver provided by the OS.
DGuen
HP EliteBook
Windows 10 10586
Intel Centrino Ultimate-N 6300 AGN
I also encountered reliability issues with inbox driver 15.16.0.2. Workaround which appears to be working is simply turning off high performance 802.11n mode within device manager. Driver is now connecting to access point at 54 Mbps which is sufficient for my use.
ASouz7
borninacadilac,
Thank you for sharing your workaround. We are sure it will help other customers out there.
