Wireless
8506 Discusiones
Wrong version of wireless driver in device manager
ASchm9
Principiante
7.341 Vistas
So I just installed a new driver for my Wireless-AC 7260 (18.40.0) and when I go into device manager, it still reports the driver as 18.33.0.2 which was the previous one. I want to know if this is actually a problem or not? Windows 10 64-bit Home
0 kudos
1 Solución
Empleados
5.251 Vistas
appss
Please take a look to the notes in the download page. Version number shown in device manager depends on what adapter your system has:
PROSet version = 18.40.0
Driver version = 18.40.0.9 for Windows® 10 for 18260, 8260, 3165, and 17265 adapters.
Driver version = 18.33.0.2 for Windows® 10 for 7265, 3160, and 7260 adapters.
Ver la solución en mensaje original publicado
3 Respuestas
ASouz7
Colaborador Distinguido II
5.251 Vistas
appss,
Intel recommends to always use the latest drivers provided by the OEM. However, as a second option, you can always use the generic drivers provided in our download center.
Please proceed as follows:
1. We understand you have done it already but here is the link just in case: https://downloadcenter.intel.com/product/75439/Intel-Dual-Band-Wireless-AC-7260 Drivers & Software please make sure you have the version that is according to your OS version and architecture 32 or 64 bit. Download and save it.
2. Go to Control Panel, Programs and Features and Uninstall "Intel® PROSet/Wireless Software", if it is installed. When prompted, choose the option to "Discard settings".
3. In Control Panel, Device Manager, Network Adapters, right click on the Intel® Dual Band Wireless-AC 7260 and Uninstall it. Make sure you mark the option to "Delete the driver software for this device".
4. Reboot the PC or scan for hardware changes, check device manager and if an older driver is detected and installed, repeat the actions to uninstall and delete it as well. Repeat this process until the OS does not allow deleting the driver, or until the controller shows as Unknown Device.
10. Reboot or scan for hardware changes, then uninstall and delete any older driver versions as you did for the Wireless adapter.
12. Install the Intel® Wireless driver. During the first steps of PROSet/Wireless installation, make sure to customize the installation and install all the 3 driver components.
Empleados
5.252 Vistas
appss
DDary
Novato
5.251 Vistas
I posted about this issue as well, and showed some screen captures of the discrepancies. I wish Intel would do something about this.
Responder
