I have an older Toshiba laptop - Satellite C50-A-1DV Windows 10 home. I have an Intel Centrino Advanced-N+WiMax 6250 device in my device manager that is listed as OTHER that has no driver available. I still have wireless and lan capabilities because I also have it listed as ok under my network adapters as Intel Centrino Advanced-N+WiMax 6250 AGN along with numerous other devices.
I notice that someone posted on here that they had a copy of the driver files I require, just wondering if they are willing to supply me with a copy, I have spent hours searching the internet for a copy but being discontinued don't think I am going to find one this is my last hope before I remove it and return to my slow very slow old card.
Thanks!
I have sent you download information via PM, so check your messages.
Hello tfc002
Due to this product being discontinued, Intel Customer Service no longer supports inquiries for it. You may find the Discontinued Products website (https://www.intel.com/content/www/us/en/support/discontinued-products.html) website helpful to address your request.
You can get the specifications and verify this product's discontinuance status at the Intel® Product Specifications website > Product Status > "Discontinued". https://ark.intel.com/
David G
I will send you link via PM. I am presuming you need just Windows 10 x64 version?
Yes it is and Thank you working fine now
Hello! Can you send me the drivers, too? I'm using Windows 10 x64. Your help is much appreciated. :))
Hello, could I get a copy of the driver as well?
All good now don't require it change wireless card for one i can get drivers for
hey i need that same driver for an acer aspire one on windows 7 can you get that one also please?
Hope this helps,
Hello, can I also get a copy for windows10 64bit? Thank you.
hello, i have the same problem in a lenovo all in one, the driver is with code 10, can share the driver please, thanks guys
If Scott Pearson doesn't reply with the Intel drivers try this link for lenovo nz1w303w_64
I downloaded them but ended up installing the Intel drivers for some reason I don't recall.
I checked the C:/DRIVERS folder and the Lenovo wifi driver folder is there, so they're probably the drivers I used.
The Centrino Advanced-N 6250 AGN driver version I have is 15.12.0.9 from 4/30/2015
n_scott_pearson,
ty!
when i try to exec the drivers, after prompt, a window pops up in install wizard saying that the install is blocked due to a needed rebot.
I've reboted my a-- off. still will not load.
any ideas?
Do you still have information on where to get this driver?
Try this link for lenovo nz1w303w_64 for the 64 bit drivers
I have a HP Pavilion with windows 7. I am also looking for the same driver for Intel(R) Centrino(R) Advanced-N + WiMAX 6250.
I'd appreciate the help.
Halfway down the page you'll see it lists Intel Centrino Advanced-N + WiMAX 6250, Dual Band
add Https to
They hate HTML here
The driver packages in my share also include support for this adapter.
