Wireless
8623 Discussions
Intel Centrino advanced-n 6205: Code 10
ЕБого
Hello.
I have Intel NUC D54250WYKH with latest version of BIOS and Windows 8.1 64-bit and intel centrino advanced-n 6205.
I have problem with wifi adapter.
I have error for intel centrino advanced-n 6205 Code 10. Device cannot start.
I installed latest driver for wifi adapter. I tried different drivers. Nothing helps.
Is this wifi adapter fully compatible with Win 8.1?
Maybe somebody can solve this problem?
Thank you.
ASouz7
Egor_B,
Code 10 is a driver issue. Did you do it like this when you uninstalled the drivers?
1 - Go to device manager.
2 - Right click on Intel® Centrino® Advanced-N 6205 and then left click uninstall. Make sure no file is left behind.
3 - Then, using our http://www.intel.com/p/en_US/support/detect?iid=dc_iduu Intel® Driver Update Utility seek for the drivers and install them.
Answering your question about the Intel® Centrino® Advanced-N 6205 being compatible with Windows*8.1, the answer is yes. please check this link for further information: https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProdId=3316 Intel® Download Center
Let us know if this helped you.
ЕБого
aleki_intel,
Thank you for your advice, but it is not help.
What you mean "Make sure no file is left behind"? I choose - delete drivers when deleting device.
Intel Driver Update Utility cannot found drivers for Intel Centrino Advanced-N 6205.
PIvan4
aleki_intel, hello!
Same problem with Intel NUC D34010WYKH & Centrino Advanced-N 6205 card.
I have tried 2 different 62205ANHMW cards, so I think that problem in Intel NUC or drivers or OS (Win7 x64).
And Egor_B is right! Intel Driver Update Utility doesn't find drivers for WiFi cards.
Do you have any ideas to solve this problem?
PIvan4
aleki_intel, Egor_B, hello!
I think I've found the solution.
Some WiFi cards had maded for specific models of Lenovo, HP & Samsung computers ("WhiteList" cards).
These cards has FRU number on the label.
!!Intel blocks the work of these cards in the OS drivers!!
My cards are currently working in Ubuntu & Mint, but not working in Win 7 & 8.1.
