Wireless
8514 Diskussionen
Intel Dual Band Wireless AC-3160 drivers
nice1488
Anfänger
126.923Aufrufe
I bought a LG 24V360 computer a while ago and a few days ago I formatted it for some problems, I installed the drivers but I can't find anything about Intel Dual Band Wireless AC-3160 drivers for Windows 10 and I found that it is discontinued, what can I do?
286 Antworten
n_scott_pearson
Superuser
6.812Aufrufe
@Swam,
Use this link: https://1drv.ms/f/s!AtacZBU04mo-j-tQ34BdSDv6y1BFsg?e=7gn50T to access my archive. Subfolders provide final driver packages for most of the Discontinued Wireless adapters.
Hope this helps,
Daniel_Electric_Eye
Einsteiger
6.637Aufrufe
Super Scott please rescue me too!  Do you still do that?
Gosh, everything they delete they instead ought to just turn over to the user community.  What the heck?
Daniel_Electric_Eye
Einsteiger
7.527Aufrufe
Never mind on that contact; found one of the links.  Thanks for putting them up!
n_scott_pearson
Superuser
7.284Aufrufe
Intel released only a single driver package that contained the compatibility fixes for WiFi 6 routers. Then, almost immediately afterwards, they discontinued the adapter and removed support for it from the subsequent driver packages (if you install a subsequent package, it will not update the driver as you would expect). No, you must specifically install the 21.10.1 packages (which provide the 18.33.17.1 Wireless driver and 20.100.5.1 Bluetooth driver).
Intel, in all their wisdom, next decided to remove all downloads for products that have been discontinued. Luckily, when I saw these discontinuation notices, I saved away copies of the final driver release packages in my archive. I currently have a portion of this archive in the cloud and you can download the driver packages (Wireless and Bluetooth) from there. Use this link: https://1drv.ms/f/s!AtacZBU04mo-j-tQ34BdSDv6y1BFsg?e=7gn50T to access my archive. Subfolders provide final driver packages for most of the Discontinued Wireless adapters.
Hope this helps,
Appu1
Einsteiger
7.153Aufrufe
Dear Scott,
Thanks so much for sharing, WFI is detectable now and able to connect.
Thanks & Regards,
Appu
dRiks92
Einsteiger
3.945Aufrufe
Hi ! Bluetooth of my MSI GE70 2PE Apache Pro 2014 (Intel Dualband ac 3160) couldn't detect any device after a fresh reinstall and fortunately I found your post.
I installed the BT_21.10.1_64Win10 driver (Works with W11) and it finally worked !
I created an account just to thank you !
n_scott_pearson
Superuser
7.041Aufrufe
@CGarcia31,
Use this link: https://1drv.ms/f/s!AtacZBU04mo-j-tQ34BdSDv6y1BFsg?e=7gn50T to access my archive. Subfolders provide final driver packages for almost all of the Discontinued Wireless adapters.
Hope this helps,
n_scott_pearson
Superuser
6.884Aufrufe
@Kya9576,
You don't need a private link to access it. Use the public link: https://1drv.ms/f/s!AtacZBU04mo-j-tQ34BdSDv6y1BFsg?e=7gn50T to access my archive. Subfolders provide final driver packages for almost all of the Discontinued Wireless adapters.
Hope this helps,
IC5
Einsteiger
6.675Aufrufe
Intel(R) dual band wireless-AC 7260. I can't connect to the wifi
n_scott_pearson
Superuser
5.249Aufrufe
The final release packages that included support for the 3160, 7260 and 7265-C adapters were version 21.10.1. These packages provided Wireless driver 18.33.17.1 and Bluetooth driver 20.100.5.1.
Because Intel no longer provides download support for discontinued adapters, I created a share where I make available the final driver packages for most of these adapters. Use this link: https://1drv.ms/f/s!AtacZBU04mo-j-tQ34BdSDv6y1BFsg?e=7gn50T to access this share. Subfolders provide final driver packages for most of the Discontinued Wireless adapters.
Hope this helps,
n_scott_pearson
Superuser
5.214Aufrufe
It's not a bad idea. Technically speaking, all of the drivers are up there already and available using the Wayback Machine. That's if you know how to use it. Have a knowledge of the old folder structure Intel used. Oh, and have the time it takes to dig anything out.
There's a lot of context (how-to's, etc.) that would need to be collected to make it a viable save set and this will take some time to product/collect.
n_scott_pearson
Superuser
4.840Aufrufe
Hope this helps,
P.S. Please turn off threaded display mode in preferences. If you had, you would have seen this link at the end of the conversation.
AlHill
Superuser
4.837Aufrufe
Pity that the forum software defaults to Threaded.
[Fear and the desire for control are primary motivators for shadow dwellers. ]
n_scott_pearson
Superuser
1.402Aufrufe
@lawedji,
Hope this helps,
Antworten
