Wireless
8666 Discussions
Intel Dual-Band Wireless-AC 7260
CChua14
Got the latest Intel Driver v17.16.0 for windows 8.1
Having too much lag for games and even for surfing the internet.
Try almost all the solution and nothing solve....
Microsoft Windows [Version 6.3.9600]
(c) 2013 Microsoft Corporation. All rights reserved.
C:\WINDOWS\system32>ping www.google.com -t
Pinging www.google.com [74.125.130.99] with 32 bytes of data:
Reply from 74.125.130.99: bytes=32 time=5ms TTL=44
Reply from 74.125.130.99: bytes=32 time=4ms TTL=44
Reply from 74.125.130.99: bytes=32 time=8ms TTL=44
Reply from 74.125.130.99: bytes=32 time=9ms TTL=44
Reply from 74.125.130.99: bytes=32 time=34ms TTL=44
Reply from 74.125.130.99: bytes=32 time=6ms TTL=44
Reply from 74.125.130.99: bytes=32 time=24ms TTL=44
Ping statistics for 74.125.130.99:
Packets: Sent = 17, Received = 17, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 4ms, Maximum = 34ms, Average = 8ms
Control-C
^C
C:\WINDOWS\system32>ping sgp-1.valve.net -t
Pinging sgp-1.valve.net [103.28.54.1] with 32 bytes of data:
Reply from 103.28.54.1: bytes=32 time=51ms TTL=53
Reply from 103.28.54.1: bytes=32 time=36ms TTL=53
Reply from 103.28.54.1: bytes=32 time=5ms TTL=53
Reply from 103.28.54.1: bytes=32 time=7ms TTL=53
Reply from 103.28.54.1: bytes=32 time=6ms TTL=53
Reply from 103.28.54.1: bytes=32 time=8ms TTL=53
Reply from 103.28.54.1: bytes=32 time=19ms TTL=53
Reply from 103.28.54.1: bytes=32 time=450ms TTL=53
Reply from 103.28.54.1: bytes=32 time=12ms TTL=53
Reply from 103.28.54.1: bytes=32 time=172ms TTL=53
Reply from 103.28.54.1: bytes=32 time=145ms TTL=53
Reply from 103.28.54.1: bytes=32 time=189ms TTL=53
Reply from 103.28.54.1: bytes=32 time=512ms TTL=53
Reply from 103.28.54.1: bytes=32 time=384ms TTL=53
Reply from 103.28.54.1: bytes=32 time=275ms TTL=53
Reply from 103.28.54.1: bytes=32 time=355ms TTL=53
Reply from 103.28.54.1: bytes=32 time=132ms TTL=53
Reply from 103.28.54.1: bytes=32 time=235ms TTL=53
Reply from 103.28.54.1: bytes=32 time=252ms TTL=53
Reply from 103.28.54.1: bytes=32 time=432ms TTL=53
Reply from 103.28.54.1: bytes=32 time=465ms TTL=53
Reply from 103.28.54.1: bytes=32 time=166ms TTL=53
Reply from 103.28.54.1: bytes=32 time=206ms TTL=53
Reply from 103.28.54.1: bytes=32 time=108ms TTL=53
Reply from 103.28.54.1: bytes=32 time=107ms TTL=53
Reply from 103.28.54.1: bytes=32 time=89ms TTL=53
Reply from 103.28.54.1: bytes=32 time=152ms TTL=53
Reply from 103.28.54.1: bytes=32 time=83ms TTL=53
Reply from 103.28.54.1: bytes=32 time=45ms TTL=53
Reply from 103.28.54.1: bytes=32 time=63ms TTL=53
Reply from 103.28.54.1: bytes=32 time=85ms TTL=53
Reply from 103.28.54.1: bytes=32 time=49ms TTL=53
Reply from 103.28.54.1: bytes=32 time=43ms TTL=53
Reply from 103.28.54.1: bytes=32 time=92ms TTL=53
Reply from 103.28.54.1: bytes=32 time=114ms TTL=53
Reply from 103.28.54.1: bytes=32 time=66ms TTL=53
Reply from 103.28.54.1: bytes=32 time=181ms TTL=53
Reply from 103.28.54.1: bytes=32 time=50ms TTL=53
Reply from 103.28.54.1: bytes=32 time=15ms TTL=53
Reply from 103.28.54.1: bytes=32 time=11ms TTL=53
Reply from 103.28.54.1: bytes=32 time=236ms TTL=53
Reply from 103.28.54.1: bytes=32 time=30ms TTL=53
Reply from 103.28.54.1: bytes=32 time=10ms TTL=53
Reply from 103.28.54.1: bytes=32 time=9ms TTL=53
Reply from 103.28.54.1: bytes=32 time=34ms TTL=53
Reply from 103.28.54.1: bytes=32 time=29ms TTL=53
Reply from 103.28.54.1: bytes=32 time=123ms TTL=53
Reply from 103.28.54.1: bytes=32 time=73ms TTL=53
Reply from 103.28.54.1: bytes=32 time=13ms TTL=53
Reply from 103.28.54.1: bytes=32 time=91ms TTL=53
Reply from 103.28.54.1: bytes=32 time=38ms TTL=53
Reply from 103.28.54.1: bytes=32 time=26ms TTL=53
Reply ...
ASouz7
Hello ClementSysm,
Usually, lag could be caused by a background application/service spiking processor usage. Run Windows Performance Monitor to scan your system. Here is the link: https://technet.microsoft.com/en-us/library/cc749249.aspx Windows Performance Monitor - On Windows 8.1 you can find this feature on task manager by clicking on on the start button on the bottom left go into task manager as shown in the picture below.Please understand that lagging may not be related to the wireless card.
Is this card the original one that came installed in your system when you bought it ? ,
Have you checked if the antennas if they are setup properly?
Below are some links that can help you improve connectivity. If you are experiencing issues related to your connectivity with this card.
http://www.intel.com/support/wireless/wlan/sb/CS-025332.htm Intel® Wi-Fi Products — Resolving Wi-Fi Network Connection Issues
http://www.intel.com/support/wireless/wlan/sb/CS-006321.htm Intel® Wi-Fi Products — Access Point (AP) Firmware Updates May Resolve Wireless Network Issues
http://www.intel.com/support/wireless/wlan/sb/CS-025393.htm Intel® Wi-Fi Products — What Are the Advanced Wi-Fi Adapter Settings?
http://www.intel.com/support/wireless/wlan/sb/CS-034875.htm Intel® Wi-Fi Products — TechNote: Access Point Interoperability Issue with uAPSD
On our best effort to help you reduce game lag you can do the following:
You can typically reduce game lag by either lowering the performance settings for the given game or by upgrading certain parts on your computer. The amount of Random Access Memory (RAM) you have available and the quality of your graphics card are the two most important variables in providing a lag-free gaming experience. Running other programs while simultaneously playing a game can also drain system resources and cause lag. Understanding how to reduce game lag will help to prevent you from getting frustrated with slower-than-usual game response.
1 - Lower graphics settings in the game setting menu - *These features are merely illustrative and may differ from that of your game(s)
Go to the game that you are experiencing lag
Go the video options once the game has loaded and select graphics option as shown in the picture below:
Picture 1
Picture 2
2 - Reduce your resolution until you find a sweet spot at which then game runs smoothly enough for you, while still retaining acceptable graphics.
This is as far as we can go on our best effort to help you with the lag when playing games.
ASouz7
Hello ClementSysm,
Picture 1
Picture 2
