- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I have sent you a download link via the Communities Private Message (PM) service. For this message, check your PM inbox. Click on your avatar picture in the top right corner of the page (in the blue Communities banner) and then select Messages from the resulting menu.
P.S. You are the 322nd WLAN Driver requestor since Jan. 6th.
Lien copié
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Dear Mr. n_scott_pearson,
I am attempting to upgrade my laptop with a Intel 7260.HMW Dual Band Wireless-AC 7260 Network Adapter PCI Half Mini Card 802.11 and have been searching the net for a few hours trying unsuccessfully to acquire the drivers for this card to work on my Windows 7 32 Bit laptop.
Upon all my searching, you seem to be the one individual who knows how to make this magic happen. Would you be able to supply me with the drivers for this?
Thank you kindly in advance for all your help and knowledge.
Much appreciated!
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I have a intel dual band ac-7260.
Can I get the latest driver for this card for windows 10(64bit).
Much appreciated!
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi Scott, I am also having problems with my AC 7260 dis-connecting. I am running the latest WIN10 in Lenovo Thinkpad Yoga 14. Can you share the drivers. Thanks!
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi @n_scott_pearson ,
I am having the same issue with my WIFI card disconnecting,
I would also really appreciate a copy of the drivers so I can try and resolve this problem!
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello there!
I.ve updated my HP pavillion x360 with de intel ac7260 dual band and cant find the drivers!
could you help me?
Thank you
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hope this helps,
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I created an account (even though I used fake credentials) just so I could to thank you. You were more helpful than anyone else in this 200 billion dollar company. You are our hero
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Thank you so much, I was at my wits end troubleshooting WiFi on my laptop and you have saved the day.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Can you also send me a link to dowload the latest version of driver for Intel Dualband AC-7260 for Windows 10 x64 ?
Thanks you very much !
Vincent
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hope this helps,
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello !
Perfect, it works ! My laptop can now connect to a 802.11ax router in 802.11ac mode. So... My laptop is not (yet) too old !
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi Scott,
I've read several posts thanking you for your help. I have clicked on the link for solution in original post. It downloads the file, but when I choose execute, I get the response 'the selected driver cannot be installed on your system'
I have an ASUS pc with AC 7260
My netgear router died and I bought a TPlink Archer AXE95. Online info said it was backwards compatible to 11n and the guy at Best Buy confirmed; says so on the box. Of course, the box also says 'setup and management made easy" LOL The tether app I used on my phone eventually enabled my Samsung S23 phone to connect, and my fairly old Panasonic TV connects, but what I need most, my laptop, I've just been going round in circles.
Is this not going to work on my ASUS? If not, I'll have to take the router back. Can't afford a new PC while this one is working fine.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hola como estas...
Discúlpame es que al parecer tu tiene mucho conocimiento en pc en mi caso es nulo me puede ayudar por favor. no me coge el wifi de mi compu es un hp y me dice que el controlador del wifi Intel(R) Dual Band Wireless-N 7260 y no me funciona.
me puedes ayudar por favor
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi Scoot, can you please send me the link to the driver as well. I'm facing the same issue.
-Caesar
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi n_scott_pearson,
I also having the issue with Intel dual band AC-7260 driver.
My Dell laptop using the AC-7260 driver, some wifi networks can't be seen by this driver.
Luckily, I found out online that you can help.
Please forward me the solution.
Many Thanks!
Jason
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
It sounds like the Wireless driver you have is old and cannot 'see' WiFi 6 or later routers. You need to ensure that your have the latest (and final) driver released for this adapter. I have this driver package in my archive (which is fully public now, BTW). Use this link: https://1drv.ms/f/s!AtacZBU04mo-j-tQ34BdSDv6y1BFsg?e=7gn50T to access my archive. Subfolders provide final driver packages for most of the Discontinued Wireless adapters.
Hope this helps,
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
P.S. You are the 326th WLAN Driver requestor since Jan. 6th.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Thanks n_scott_pearson!
Greatly appreciate the help. I have sent you a PM in response to yours.
Thanks again!
MisterMike
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
