Wireless
8282 Discussions
Intel Killer Ax1675i doesn't work with Linux
mhalano
I just installed a brand new Intel Killer AX1675i wireless card, but it wasn't recognized by Linux.
I'm using Ubuntu 22.04 LTS with kernel 5.17.4.
I tried to install backport-iwlwifi-dkms but no result. I always get this on dmesg (debug enabled when loading iwlwifi module):
[ 3358.000092] iwlwifi 0000:00:14.3: iwl_trans_pcie_alloc HW REV: 0x351
[ 3358.000699] iwlwifi 0000:00:14.3: iwl_pcie_set_interrupt_capa MSI-X enabled. 16 interrupt vectors were allocated
[ 3358.000702] iwlwifi 0000:00:14.3: iwl_pcie_set_interrupt_capa MSI-X enabled with rx queues 15, vec mask 0x0
[ 3358.001676] iwlwifi 0000:00:14.3: iwl_pcie_prepare_card_hw iwl_trans_prepare_card_hw enter
[ 3358.001700] iwlwifi 0000:00:14.3: iwl_pcie_set_hw_ready hardware ready
[ 3358.001714] iwlwifi: No config found for PCI dev 43f0/1672, rev=0x351, rfid=0x2010d000
[ 3358.001720] iwlwifi 0000:00:14.3: iwl_pcie_rx_free Free NULL rx context
[ 3358.001732] iwlwifi: probe of 0000:00:14.3 failed with error -22
The PCI ID for this card is 43F0:1672. I find in the Linux source code (more specifically in the file https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/drivers/net/wireless/intel/iwlwifi/pcie/drv.c) mentions to 43F0 and 1672, but never together, so I think this is the missing piece. The problem is there are  lots of types of WiFi cards, and that the point I need clarification.
I found reference to 43F0 being Qu devices (I really don't know what is that, but there is a generic line about it) and 1672 related to 1675i (my model of wireless card). Anyone knows where the type of the card with this PCI ID or know where I can find details about the types (Qu, So, So with GF2, Ma Bz, etc.)?
mhalano
Hello  Steven,
You can close this problem. Even I couldn't fix, I bought and installed a AX1675x which is working relatively well. It has its own problems, but they are more manageable than AX1675i which doesn't work at all.
Steven_Intel
Hello mhalano,
In order to better assist you, please run the #lspci command and check if the system recognizes the model of the wireless card.
As well, please run a report using the Intel® System Support Utility for Linux (https://www.intel.com/content/www/us/en/download/18895/26735/intel-system-support-utility-for-the-linux-operating-system.html?) and attach it to your reply.
Steven G.
mhalano
Here it is the lspci result:
➜ lspci
00:00.0 Host bridge: Intel Corporation 11th Gen Core Processor Host Bridge/DRAM Registers (rev 05)
00:01.0 PCI bridge: Intel Corporation 11th Gen Core Processor PCIe Controller #1 (rev 05)
00:02.0 VGA compatible controller: Intel Corporation TigerLake-H GT1 [UHD Graphics] (rev 01)
00:04.0 Signal processing controller: Intel Corporation TigerLake-LP Dynamic Tuning Processor Participant (rev 05)
00:06.0 PCI bridge: Intel Corporation 11th Gen Core Processor PCIe Controller #0 (rev 05)
00:07.0 PCI bridge: Intel Corporation Tiger Lake-H Thunderbolt 4 PCI Express Root Port #0 (rev 05)
00:0a.0 Signal processing controller: Intel Corporation Tigerlake Telemetry Aggregator Driver (rev 01)
00:0d.0 USB controller: Intel Corporation Tiger Lake-H Thunderbolt 4 USB Controller (rev 05)
00:0d.2 USB controller: Intel Corporation Tiger Lake-H Thunderbolt 4 NHI #0 (rev 05)
00:14.0 USB controller: Intel Corporation Tiger Lake-H USB 3.2 Gen 2x1 xHCI Host Controller (rev 11)
00:14.2 RAM memory: Intel Corporation Tiger Lake-H Shared SRAM (rev 11)
00:14.3 Network controller: Intel Corporation Tiger Lake PCH CNVi WiFi (rev 11)
00:15.0 Serial bus controller: Intel Corporation Tiger Lake-H Serial IO I2C Controller #0 (rev 11)
00:15.1 Serial bus controller: Intel Corporation Device 43e9 (rev 11)
00:16.0 Communication controller: Intel Corporation Tiger Lake-H Management Engine Interface (rev 11)
00:17.0 SATA controller: Intel Corporation Device 43d3 (rev 11)
00:1d.0 PCI bridge: Intel Corporation Tiger Lake-H PCI Express Root Port #9 (rev 11)
00:1d.5 PCI bridge: Intel Corporation Device 43b5 (rev 11)
00:1f.0 ISA bridge: Intel Corporation Tiger Lake-H LPC/eSPI Controller (rev 11)
00:1f.3 Multimedia audio controller: Intel Corporation Tiger Lake-H HD Audio Controller (rev 11)
00:1f.4 SMBus: Intel Corporation Tiger Lake-H SMBus Controller (rev 11)
00:1f.5 Serial bus controller: Intel Corporation Tiger Lake-H SPI Controller (rev 11)
01:00.0 VGA compatible controller: NVIDIA Corporation GA106M [GeForce RTX 3060 Mobile / Max-Q] (rev a1)
01:00.1 Audio device: NVIDIA Corporation Device 228e (rev a1)
02:00.0 Non-Volatile memory controller: ADATA Technology Co., Ltd. Device 33f3 (rev 03)
2d:00.0 Non-Volatile memory controller: Kingston Technology Company, Inc. Device 500f (rev 03)
2e:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. Device 2600 (rev 21)
(Virus scan in progress ...)
Steven_Intel
Thank you for your response.
It seems that your system it is not identifying the wireless card. For that reason, please try the following:
  • Make sure the wireless card is properly integrated.
  • If you have checked that it is properly integrated and the issue persists, please try installing Windows 10/11 and then check if the system is able to identify it.
As well, since you are integrating a wireless adapter, please read the following article regarding wireless adapter integration https://www.intel.com/content/www/us/en/support/articles/000005687/wireless.html
Steven G.
mhalano
Steven,
That is my main machine. I can't change the OS. I already opened a bug report with Linux kernel.
Could you research to find out if there are wireless cards produced by Intel with this PCI ID or if it is a counterfeit? It would be helpful to check if I need a new card or the Linux kernel need an improvement.
Steven_Intel
I will proceed to research more about this issue. As soon as I have an update, I will let you know.
Steven G.
Steven_Intel
Hello mhalano,
In order to continue, please run the following commands:
  • Type $ hostnamectl in order to get the Ubuntu OS and kernel.
  • Type # lspci​ and provide a screenshot of the output command.
  • Type # modinfo iwlwifi and provide a screenshot of the output command.
  • Type # lsmod | grep iwlwifi​ and provide a screenshot of the output command.
Then, please collect the debug data:
  • Type: # dmesg | grep ASSERT​
If the output is empty, please follow this wiki: https://wireless.wiki.kernel.org/en/users/drivers/iwlwifi/debugging ​to extract dmesg and trace-cmd. If the output has value, please collect from the wiki FW dump too.
Steven G.
mhalano
➜ hostnamectl
Static hostname: glados
Icon name: computer-laptop
Chassis: laptop
Machine ID: 380bd6ea8cb24453b0023de7631f4cbb
Boot ID: 3fed0dfff0e540488810a6dd4782e347
Operating System: Ubuntu 22.04 LTS
Kernel: Linux 5.17.5-051705-generic
Architecture: x86-64
modinfo iwlwifi had a very long exit, so I copy and paste:
➜ modinfo iwlwifi
filename: /lib/modules/5.17.5-051705-generic/updates/dkms/iwlwifi.ko
version: iwlwifi-stack-public:master:9858:4c7cba27
license: GPL
description: Intel(R) Wireless WiFi driver for Linux
firmware: iwlwifi-7265D-29.ucode
firmware: iwlwifi-7265-17.ucode
firmware: iwlwifi-3168-29.ucode
firmware: iwlwifi-3160-17.ucode
firmware: iwlwifi-7260-17.ucode
firmware: iwlwifi-8265-36.ucode
firmware: iwlwifi-8000C-36.ucode
firmware: iwlwifi-9260-th-b0-jf-b0-46.ucode
firmware: iwlwifi-9000-pu-b0-jf-b0-46.ucode
firmware: iwlwifi-BzBnj-a0-fm-b0-73.ucode
firmware: iwlwifi-gl-b0-fm-a0-73.ucode
firmware: iwlwifi-bz-a0-fm4-a0-73.ucode
firmware: iwlwifi-BzBnj-a0-hr-b0-73.ucode
firmware: iwlwifi-BzBnj-a0-gf4-a0-73.ucode
firmware: iwlwifi-BzBnj-a0-gf-a0-73.ucode
firmware: iwlwifi-BzBnj-a0-fm4-a0-73.ucode
firmware: iwlwifi-BzBnj-a0-fm-a0-73.ucode
firmware: iwlwifi-gl-a0-fm-a0-73.ucode
firmware: iwlwifi-bz-a0-fm-a0-73.ucode
firmware: iwlwifi-bz-a0-mr-a0-73.ucode
firmware: iwlwifi-bz-a0-gf4-a0-73.ucode
firmware: iwlwifi-bz-a0-gf-a0-73.ucode
firmware: iwlwifi-bz-a0-hr-b0-73.ucode
firmware: iwlwifi-SoSnj-a0-mr-a0-73.ucode
firmware: iwlwifi-ma-a0-fm-a0-73.ucode
firmware: iwlwifi-ma-a0-mr-a0-73.ucode
firmware: iwlwifi-ma-a0-gf4-a0-73.ucode
firmware: iwlwifi-ma-a0-gf-a0-73.ucode
firmware: iwlwifi-ma-a0-hr-b0-73.ucode
firmware: iwlwifi-SoSnj-a0-jf-b0-73.ucode
firmware: iwlwifi-SoSnj-a0-hr-b0-73.ucode
firmware: iwlwifi-SoSnj-a0-gf-a0-73.ucode
firmware: iwlwifi-SoSnj-a0-gf4-a0-73.ucode
firmware: iwlwifi-ty-a0-gf-a0-73.ucode
firmware: iwlwifi-so-a0-gf-a0-73.ucode
firmware: iwlwifi-so-a0-hr-b0-73.ucode
firmware: iwlwifi-so-a0-jf-b0-73.ucode
firmware: iwlwifi-cc-a0-73.ucode
firmware: iwlwifi-QuQnj-b0-jf-b0-73.ucode
firmware: iwlwifi-QuZ-a0-jf-b0-73.ucode
firmware: iwlwifi-QuZ-a0-hr-b0-73.ucode
firmware: iwlwifi-Qu-b0-jf-b0-73.ucode
firmware: iwlwifi-Qu-c0-hr-b0-73.ucode
firmware: iwlwifi-QuQnj-b0-hr-b0-73.ucode
firmware: iwlwifi-Qu-b0-hr-b0-73.ucode
srcversion: C8C035BF98B2B803370CFB9
alias: pci:v00008086d00007740sv*sd*bc*sc*i*
alias: pci:v00008086d0000A840sv*sd*bc*sc*i*
alias: pci:v00008086d00002727sv*sd*bc*sc*i*
alias: pci:v00008086d00007E40sv*sd*bc*sc*i*
alias: pci:v00008086d00002729sv*sd*bc*sc*i*
alias: pci:v00008086d00007F70sv*sd*bc*sc*i*
alias: pci:v00008086d000054F0sv*sd*bc*sc*i*
alias: pci:v00008086d000051F1sv*sd*bc*sc*i*
alias: pci:v00008086d000051F0sv*sd*bc*sc*i*
alias: pci:v00008086d00007AF0sv*sd*bc*sc*i*
alias: pci:v00008086d00007A70sv*sd*bc*sc*i*
alias: pci:v00008086d00002726sv*sd*bc*sc*i*
alias: pci:v00008086d00002725sv*sd*bc*sc*i*
alias: pci:v00008086d00002725sv*sd00000000bc*sc*i*
alias: pci:v00008086d00002723sv*sd*bc*sc*i*
alias: pci:v00008086d00002720sv*sd*bc*sc*i*
alias: pci:v00008086d0000A0F0sv*sd*bc*sc*i*
alias: pci:v00008086d000043F0sv*sd*bc*sc*i*
alias: pci:v00008086d00004DF0sv*sd*bc*sc*i*
alias: pci:v00008086d00003DF0sv*sd*bc*sc*i*
alias: pci:v00008086d000034F0sv*sd*bc*sc*i*
alias: pci:v00008086d000006F0sv*sd*bc*sc*i*
alias: pci:v00008086d000002F0sv*sd*bc*sc*i*
alias: pci:v00008086d0000A370sv*sd*bc*sc*i*
alias: pci:v00008086d00009DF0sv*sd*bc*sc*i*
alias: pci:v00008086d000031DCsv*sd*bc*sc*i*
alias: pci:v00008086d000030DCsv*sd*bc*sc*i*
alias: pci:v00008086d0000271Csv*sd*bc*sc*i*
alias: pci:v00008086d0000271Bsv*sd*bc*sc*i*
alias: pci:v00008086d00002526sv*sd*bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00009074bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000014bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000012bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00001012bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00003E01bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00003E02bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00001014bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000850bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000950bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000930bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000910bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00008130bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00009110bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000810bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00008010bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00008050bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00008110bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00009010bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000150bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000050bc*sc*i*
alias: pci:v00008086d000024FDsv*sd000010D0bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00001010bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000130bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00001130bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00001110bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000110bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000010bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00004010bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000000bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000930bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000950bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000850bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000910bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000810bc*sc*i*
alias: pci:v00008086d000024F6sv*sd00000030bc*sc*i*
alias: pci:v00008086d000024F5sv*sd00000010bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000044bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000004bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00009150bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00009050bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00008150bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00008050bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00009132bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00008132bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00009130bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00008130bc*sc*i*
alias: pci:v00008086d000024F4sv*sd0000D030bc*sc*i*
alias: pci:v00008086d000024F4sv*sd0000C030bc*sc*i*
alias: pci:v00008086d000024F4sv*sd00009030bc*sc*i*
alias: pci:v00008086d000024F4sv*sd00008030bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00009110bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00009010bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00008110bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00008010bc*sc*i*
alias: pci:v00008086d000024F3sv*sd0000B0B0bc*sc*i*
alias: pci:v00008086d000024F3sv*sd0000D0B0bc*sc*i*
alias: pci:v00008086d000024F3sv*sd0000D050bc*sc*i*
alias: pci:v00008086d000024F3sv*sd0000C050bc*sc*i*
alias: pci:v00008086d000024F3sv*sd0000D010bc*sc*i*
alias: pci:v00008086d000024F3sv*sd0000C110bc*sc*i*
alias: pci:v00008086d000024F3sv*sd0000C010bc*sc*i*
alias: pci:v00008086d000024F4sv*sd00001030bc*sc*i*
alias: pci:v00008086d000024F4sv*sd00000030bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00001150bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000150bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00001050bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000250bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000050bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00001110bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00001012bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000012bc*sc*i*
alias: pci:v00008086d000024F3sv*sd000001F0bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000110bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00001132bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000132bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00001130bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000130bc*sc*i*
alias: pci:v00008086d000024F3sv*sd000010B0bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00001010bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000010bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009E10bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009400bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009000bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd0000520Abc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00005212bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005F10bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005490bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00005290bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005590bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005190bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005090bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005420bc*sc*i*
alias: pci:v00008086d0000095Asv*sd0000502Abc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005020bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009410bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00009310bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009510bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00009200bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00009210bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009112bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009110bc*sc*i*
alias: pci:v00008086d0000095Asv*sd0000900Abc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009012bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009010bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00005202bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005102bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005002bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00005200bc*sc*i*
alias: pci:v00008086d0000095Asv*sd0000500Abc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005000bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00001010bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005400bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005510bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005410bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005412bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005012bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005C10bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00005210bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00005302bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00005310bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005100bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005110bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005010bc*sc*i*
alias: pci:v00008086d000024FBsv*sd00000000bc*sc*i*
alias: pci:v00008086d000024FBsv*sd00002150bc*sc*i*
alias: pci:v00008086d000024FBsv*sd00002050bc*sc*i*
alias: pci:v00008086d000024FBsv*sd00002110bc*sc*i*
alias: pci:v00008086d000024FBsv*sd00002010bc*sc*i*
alias: pci:v00008086d00003165sv*sd00008110bc*sc*i*
alias: pci:v00008086d00003165sv*sd00008010bc*sc*i*
alias: pci:v00008086d00003166sv*sd00004210bc*sc*i*
alias: pci:v00008086d00003166sv*sd00004310bc*sc*i*
alias: pci:v00008086d00003165sv*sd00004110bc*sc*i*
alias: pci:v00008086d00003165sv*sd00004510bc*sc*i*
alias: pci:v00008086d00003165sv*sd00004410bc*sc*i*
alias: pci:v00008086d00003166sv*sd00004212bc*sc*i*
alias: pci:v00008086d00003165sv*sd00004012bc*sc*i*
alias: pci:v00008086d00003165sv*sd00004010bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00001170bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00001070bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00008570bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00008470bc*sc*i*
alias: pci:v00008086d000008B4sv*sd00008272bc*sc*i*
alias: pci:v00008086d000008B4sv*sd00008370bc*sc*i*
alias: pci:v00008086d000008B4sv*sd00008270bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00008062bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00008060bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00008172bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00008170bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00008072bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00008070bc*sc*i*
alias: pci:v00008086d000008B4sv*sd00000370bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00000472bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00000470bc*sc*i*
alias: pci:v00008086d000008B4sv*sd00000272bc*sc*i*
alias: pci:v00008086d000008B4sv*sd00000270bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00000062bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00000060bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00000172bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00000170bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00000072bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00000070bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C420bc*sc*i*
alias: pci:v00008086d000008B2sv*sd0000C220bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C02Abc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C020bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C360bc*sc*i*
alias: pci:v00008086d000008B2sv*sd0000C370bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C560bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C570bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C462bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C460bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C472bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C470bc*sc*i*
alias: pci:v00008086d000008B2sv*sd0000C262bc*sc*i*
alias: pci:v00008086d000008B2sv*sd0000C26Abc*sc*i*
alias: pci:v00008086d000008B2sv*sd0000C260bc*sc*i*
alias: pci:v00008086d000008B2sv*sd0000C272bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000CC60bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000CC70bc*sc*i*
alias: pci:v00008086d000008B2sv*sd0000C270bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C760bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C770bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C162bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C062bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C160bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C06Abc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C060bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C170bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C072bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C070bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004420bc*sc*i*
alias: pci:v00008086d000008B2sv*sd00004220bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000402Abc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004020bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00005770bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00005170bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00005072bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00005070bc*sc*i*
alias: pci:v00008086d000008B2sv*sd00004360bc*sc*i*
alias: pci:v00008086d000008B2sv*sd00004370bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004560bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004570bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004A6Cbc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004A6Ebc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004A70bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000486Ebc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004870bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004462bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000446Abc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004460bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004472bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004470bc*sc*i*
alias: pci:v00008086d000008B2sv*sd00004262bc*sc*i*
alias: pci:v00008086d000008B2sv*sd0000426Abc*sc*i*
alias: pci:v00008086d000008B2sv*sd00004260bc*sc*i*
alias: pci:v00008086d000008B2sv*sd00004272bc*sc*i*
alias: pci:v00008086d000008B2sv*sd00004270bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004162bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004062bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004160bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000406Abc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004060bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004C70bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004C60bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004170bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004072bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004070bc*sc*i*
depends: compat,cfg80211,iwlmei
retpoline: Y
vermagic: 5.17.5-051705-generic SMP preempt mod_unload modversions
sig_id: PKCS#7
signer: glados Secure Boot Module Signature key
sig_key: 35:50:F8:38:9E:61:AA:F1:0A:93:23:B6:65:6B:46:CB:48:E2:07:49
sig_hashalgo: sha512
signature: 56:01:65:4E:0D:6D:A5:16:21:20:FE:86:F9:1D:57:FA:19:29:E8:B3:
AF:76:2B:EC:D4:D0:BE:EB:4D:5F:42:5C:E0:0F:3E:9C:E8:CD:3B:E6:
E6:02:16:9D:16:4A:B5:4B:61:B5:9E:9F:74:0C:9F:08:F1:4A:25:F2:
13:63:E6:CE:F8:E9:6A:04:30:4D:6F:86:3E:8C:B3:59:67:FD:71:82:
3F:74:B4:CF:12:26:79:1C:32:74:A6:5E:6B:33:30:2C:95:E7:BE:CE:
0B:9A:EE:6B:5E:1A:64:0F:24:A1:66:1A:C0:B2:1D:40:D3:13:8C:6B:
65:57:48:7C:E8:D2:84:AB:EA:5C:CE:DD:84:EF:39:BD:AF:EA:3A:6B:
62:EF:34:5B:BC:3C:AF:8B:19:D4:9F:7E:02:47:79:2E:04:B8:53:4B:
35:3F:43:BC:60:F4:E5:3A:52:4D:6D:53:95:63:36:23:11:9D:EB:DC:
A1:70:82:2B:0C:51:8A:21:70:A3:6B:FE:03:3D:41:28:79:DD:16:83:
8F:15:A1:2F:DA:FF:76:13:89:75:71:F5:DC:F9:63:55:96:BE:BC:86:
5B:77:75:57:2B:15:87:FF:C7:F0:3B:11:0D:FB:11:37:7B:1F:EE:23:
B2:0E:4F:66:31:8E:B0:F2:C2:DE:0D:80:D3:50:83:C4
parm: debug:debug output mask (uint)
parm: xvt_default_mode:xVT is the default operation mode (default: false) (bool)
parm: swcrypto:using crypto in software (default 0 [hardware]) (int)
parm: 11n_disable:disable 11n functionality, bitmap: 1: full, 2: disable agg TX, 4: disable agg RX, 8 enable agg TX (uint)
parm: amsdu_size:amsdu size 0: 12K for multi Rx queue devices, 2K for AX210 devices, 4K for other devices 1:4K 2:8K 3:12K (16K buffers) 4: 2K (default 0) (int)
parm: fw_restart:restart firmware in case of error (default true) (bool)
parm: nvm_file:NVM file name (charp)
parm: uapsd_disable:disable U-APSD functionality bitmap 1: BSS 2: P2P Client (default: 3) (uint)
parm: enable_ini:0:disable, 1-15:FW_DBG_PRESET Values, 16:enabled without preset value defined,Debug INI TLV FW debug infrastructure (default: 16)
parm: bt_coex_active:enable wifi/bt co-exist (default: enable) (bool)
parm: led_mode:0=system default, 1=On(RF On)/Off(RF Off), 2=blinking, 3=Off (default: 0) (int)
parm: power_save:enable WiFi power management (default: disable) (bool)
parm: power_level:default power save level (range from 1 - 5, default: 1) (int)
parm: disable_11ac:Disable VHT capabilities (default: false) (bool)
parm: disable_11ax:Disable HE capabilities (default: false) (bool)
parm: disable_msix:Disable MSI-X and use MSI instead (default: false) (bool)
parm: remove_when_gone:Remove dev from PCIe bus if it is deemed inaccessible (default: false) (bool)
parm: disable_11be:Disable EHT capabilities (default: false) (bool)
I think the trace-cmd wouldn't be very interesting since iwlwifi module isn't loaded correctly.
Steven_Intel
We are going to work on this issue, as soon as I have an update, I will let you know.
Steven G.
Steven_Intel
Hello mhalano,
After investigating and working on this case, we recommend you to install the latest Intel equivalent driver for AX1675, which would be drivers for the AX210.
If the issue persists, you will need to reach out to the Linux community for support, as Killer has no support for Linux.
Steven G.
mhalano
Steven_Intel
While the wireless adapter it is compatible with Linux, the support for Linux is very limited. That is why we recommend reaching out to the Linux community, based on the steps performed already.
Please let me know if you have any concerns.
Steven G.
Steven_Intel
Hello mhalano,
We would like to know if you have any further concerns. In case you do, we would highly appreciate it if you would let us know.
Steven G.
mhalano
Hello  Steven,
Steven_Intel
Since the thread is now solved, we will proceed to close it.
Steven G.
