- Contrassegnare come Nuovo
- Preferito
- Iscriversi
- Disattiva notifiche
- Iscriversi a feed RSS
- Evidenziare
- Stampare
- Segnalare contenuto inappropriato
Why is this showing twice with the same version number after the latest update of Intel Killer Performance Suite version 35.23.826?
It was not changing the duplicate message even after a reboot, I had to press Refresh Results to get rid of the duplicate message.
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Hi Isaac,
I may have tried to reinstall Intel DSA on one of the machines and it did not help.
There was no point of doing it on all the other machines since I found out that a simple click on "Refresh Results" fixed the problem of the duplicate message. For me it is no longer a problem, all machines corrected the issue by a click on Refresh Results.
The next day there was also an update of MS Edge which is now version 118.0.2088.46, no idea if that makes any difference. 🤷
Link copiato
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Hello FG
Based on the screenshots provided, we have noticed that those screenshots are taken from the driver Installation History in Intel® Driver & Support Assistant (Intel® DSA), that indicates to the user that they are viewing that section of the information in Intel® DSA.
This highlights the Installation History section, so it's seen as a separate section of information from the Available Updates section. The Installation History is a new feature that was added to Intel® DSA in December with the version 22.8.50 release.
We have observed that all of your drivers are currently up-to-date with no pending updates, and the installation of the Killer driver was successful. We would appreciate it if you could inform us if you are experiencing any additional performance-related concerns or similar issues with your PC.
Isaac Q.
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Hi Isaac,
The only unusual thing is that the history was showing twice the same update with the same version even after a reboot.
Had the click on Refresh Results to correct and eliminate the duplicate message, as you see on the last part of the update post.
F.G.
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Hello @FG
I appreciate your prompt response.
In order to furnish you with a precise response concerning the IDSA behavior, I will need to investigate this matter with our dedicated team to ascertain whether it deviates from the norm.
To facilitate this, I kindly request that you furnish me with the following details:
· SSU: Please download and scan your system using our tool, Intel® System Support Utility so we can help check your system info first. Once finished downloading, open the tool, click on scan 'Everything', click next, then save the system information to a .txt file. Please provide the .txt file.
This document will be necessary to check your entire system, in order to find possible errors or incompatibilities.
· Please provide us with the Browser you are currently using to open IDSA and the IDSA version.
Additionally, we are interested in ascertaining whether you have attempted the process of uninstalling and subsequently reinstalling the IDSA tool. This approach can often effectively resolve issues associated with the IDSA. For more information check out this article: How to Uninstall the Intel® Driver & Support Assistant (Intel® DSA)
After receiving all the necessary information, we will promptly liaise with the responsible team to gather additional details, and subsequently communicate our findings to you.
Isaac Q.
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Hi Isaac,
The problem was common to 3 different machines after Intel DSA updated that driver and software.
The only thing they have in common is the Intel Killer Network adapters.
They are Dell XPS 8930 and Dell XPS 8940 machines.
This download record installs Wi-Fi, Ethernet drivers and Killer Software for the Intel® Killer™ products.
35.23.826 Release date:
October 10, 2023Size:
62.84 MB
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Dear @FG,
I wish to express our gratitude for your prompt response.
We greatly appreciate the information you provided, including details about the affected machines, driver version, and release date. Our aim is to assist you in comprehending whether the duplicate message in IDSA is a normal or expected occurrence, which is why we have sought additional information in our previous correspondence.
I would like to inquire if you have encountered any challenges in procuring the requested information. It is essential for us to obtain this data so that we may forward this matter to the relevant team for their evaluation and offer a more comprehensive explanation of the issue.
Therefore, we kindly request once more that you provide the SSU report, the web browser you are currently using to access IDSA, and the version of IDSA. Additionally, we would appreciate your response to our query regarding whether you have uninstalled and reinstalled IDSA via the IDSA uninstaller.
We eagerly await your response and the requested information.
Isaac Q.
- Preferito
- Iscriversi
- Evidenziare
- Stampare
MS Edge browser
IDSA Version 23.4.39.9
I'll upload the SSU report when I have a chance to run it.
- Preferito
- Iscriversi
- Evidenziare
- Stampare
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Dear @FG,
I appreciate your prompt response and the information you provided, including the details about the SSU, Browser, and IDSA versions. However, it appears that our initial question regarding the use of the Uninstaller tool to uninstall and reinstall the IDSA remains unanswered. We would like to confirm whether you have attempted this option.
Furthermore, thank you for sharing the additional information. We will now proceed to internally review this matter with the relevant team to determine whether this issue is common, indicative of a bug, or possibly related to the browser or other factors. We will ensure to reach out to you at the earliest convenience with our findings.
Thank you for your patience.
Isaac Q.
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Hi Isaac,
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Dear @FG,
Given that the issue you reported does not constitute a significant concern and you have successfully resolved it by utilizing the "Refresh Results" function, which effectively eliminated the problem of duplicate messages across all your devices, we are prepared to conclude this case.
We extend our gratitude for your valuable time and the information you have shared with us throughout this process. We are pleased to learn of your solution and appreciate your willingness to share it, potentially assisting other community members facing similar challenges.
As the matter at hand has been resolved, we will proceed to close this thread. Please be aware that Intel will no longer actively monitor this thread. We appreciate your understanding.
Isaac Q.
- Preferito
- Iscriversi
- Evidenziare
- Stampare
The problem showed up again with latest update of Intel Killer Performance Suite 35.23.1292.
This time refresh results did not help. The problem of the duplicate message is persistent.
Detailed Report
Last scan: 1/10/2024 4:00 PM
Computer
Dell Inc. XPS 8940ManufacturerModelVersionBiosVersionDate
| Dell Inc. |
| 0K3CM7 |
| A00 |
| 2.16.0 |
| 11/2/2023 |
Operating System
Microsoft Windows 11 Pro (64-bit)VersionBuild
| 23H2 (10.0.22631) |
Processor
11th Gen Intel® Core™ i7-11700 @ 2.50GHzDevice DetailsManufacturerDescriptionArchitecture# of Cores# of ThreadsProcessor Base FrequencyCurrent VoltageLevel 2 CacheLevel 3 CacheProcessor IdAvailability
| GenuineIntel |
| Intel64 Family 6 Model 167 Stepping 1 |
| x64 |
| 8 |
| 16 |
| 2501 MHz |
| 8. |
| 4096 Kb |
| 16384 Kb |
| 0xA0671 |
| Running at full power |
Intel® UHD Graphics 750Driver DetailsProviderVersionDateDevice DetailsAdapter CompatibilityVideo ProcessorAdapter DAC TypeAvailabilityStatusLocationDevice IdNVIDIA GeForce RTX 3060 TiDriver DetailsProviderVersionDateDevice DetailsAdapter CompatibilityVideo ProcessorResolutionBits Per PixelNumber of ColorsRefresh Rate - CurrentRefresh Rate - MaximumRefresh Rate - MinimumAdapter DAC TypeAvailabilityStatusLocationDevice Id
| Intel Corporation |
| 31.0.101.5084 |
| 12/21/2023 |
| Intel Corporation |
| Intel® UHD Graphics Family |
| Internal |
| Offline |
| This device is working properly. |
| PCI bus 0, device 2, function 0 |
| PCI\VEN_8086&DEV_4C8A&SUBSYS_09C51028&REV_04\3&11583659&1&10 |
| NVIDIA |
| 31.0.15.4633 |
| 12/6/2023 |
| NVIDIA |
| NVIDIA GeForce RTX 3060 Ti |
| 3840 x 2160 |
| 32 |
| 4294967296 |
| 60 Hz |
| 75 Hz |
| 23 Hz |
| Integrated RAMDAC |
| PCI bus 2, device 0, function 0 |
| PCI\VEN_10DE&DEV_2486&SUBSYS_39711028&REV_A1\4&1A736D34&0&0008 |
Audio
Realtek AudioDriver DetailsProviderNameVersionDateDevice DetailsDevice IdUSB Audio DeviceDriver DetailsProviderNameVersionDateDevice DetailsDevice IdNVIDIA High Definition AudioDriver DetailsProviderNameVersionDateDevice DetailsDevice IdNVIDIA Virtual Audio Device (Wave Extensible) (WDM)Driver DetailsProviderNameVersionDateDevice DetailsDevice Id
| Realtek Semiconductor Corp. |
| RTKVHD64.sys |
| 6.0.9486.1 |
| 3/1/2023 |
| HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_102809C5&REV_1000\4&C896280&0&0001 |
| Microsoft |
| USBAUDIO.sys |
| 10.0.22621.2506 |
| 10/19/2023 |
| USB\VID_0BDA&PID_58B0&MI_02\6&25249C4A&0&0002 |
| NVIDIA Corporation |
| nvhda64v.sys |
| 1.3.40.14 |
| 1/19/2023 |
| HDAUDIO\FUNC_01&VEN_10DE&DEV_009E&SUBSYS_10283971&REV_1001\5&F23A98&0&0001 |
| NVIDIA |
| nvvad64v.sys |
| 4.49.0.0 |
| 9/22/2022 |
| ROOT\UNNAMED_DEVICE\0000 |
NetworkingAndIo
TAP-NordVPN Windows Adapter V9Driver DetailsProviderVersionDateDevice DetailsManufacturerAvailabilityStatusInstalledMAC AddressService NameDevice IdKiller E2600 Gigabit Ethernet ControllerDriver DetailsProviderVersionDateDevice DetailsManufacturerAvailabilityStatusInstalledMAC AddressService NameDevice IdRevisionKiller® Wi-Fi 6 AX1650i 160MHz Wireless Network Adapter (201NGW)Driver DetailsProviderVersionDateDevice DetailsManufacturerAvailabilityStatusInstalledMAC AddressService NameDevice IdRevisionBluetooth Device (Personal Area Network)Driver DetailsProviderVersionDateDevice DetailsManufacturerAvailabilityStatusInstalledMAC AddressService NameDevice IdIntel® Wireless Bluetooth®Driver DetailsProviderVersionDateDevice DetailsManufacturerStatusDevice Id
| TAP-NordVPN Windows Provider V9 |
| 9.0.0.23 |
| 5/30/2018 |
| True |
| 00:FF:B8:6A:8F:38 |
| tapnordvpn |
| ROOT\NET\0000 |
| Killer |
| 1168.15.717.2023 |
| 7/17/2023 |
| Killer |
| True |
| B0:4F:13:06:60:21 |
| e2k68cx21x64 |
| PCI\VEN_10EC&DEV_2600&SUBSYS_26001A56&REV_21\4&7374CBA&0&00E0 |
| 21 |
| Intel |
| 23.20.0.4 |
| 11/29/2023 |
| Intel Corporation |
| True |
| FC:B3:BC:AD:D0:B8 |
| Netwtw10 |
| PCI\VEN_8086&DEV_06F0&SUBSYS_16521A56&REV_00\3&11583659&1&A3 |
| 00 |
| Microsoft |
| 10.0.22621.2506 |
| 6/21/2006 |
| Microsoft |
| True |
| FC:B3:BC:AD:D0:BC |
| BthPan |
| BTH\MS_BTHPAN\6&2F573614&0&2 |
| Intel Corporation |
| 23.20.0.3 |
| 11/28/2023 |
| Intel Corporation |
| OK |
| USB\VID_8087&PID_0026\5&2c4715df&0&14 |
Memory
32 GBDevice DetailsPhysical Memory - TotalPhysical Memory - AvailableVirtual Memory - TotalVirtual Memory - AvailablePage FilePage File Space
| 32 GB |
| 22.66 GB |
| 36.41 GB |
| 25.34 GB |
| C:\pagefile.sys |
| 4.75 GB |
Storage
SanDisk SDSSDH3500GDriver DetailsProviderVersionDateDevice DetailsCapacitySerial NumberPartitionsDevice IdDevice PathFirmware DetailsVersionF:File SystemCompressedCapacityFree SpaceWDC WD10EZEX-75WN4A1Driver DetailsProviderVersionDateDevice DetailsCapacitySerial NumberPartitionsDevice IdDevice PathFirmware DetailsVersionD:File SystemCompressedCapacityFree SpaceWDC WD10EZEX-60ZF5A0Driver DetailsProviderVersionDateDevice DetailsCapacitySerial NumberPartitionsDevice IdDevice PathFirmware DetailsVersionG:File SystemCompressedCapacityFree SpaceBC511 NVMe SK hynix 512GBDriver DetailsProviderVersionDateDevice DetailsCapacitySerial NumberPartitionsDevice IdDevice PathFirmware DetailsVersionC:File SystemCompressedCapacityFree Space
| Microsoft |
| 10.0.22621.2506 |
| 6/21/2006 |
| 465.76 GB |
| 174596420281 |
| 1 |
| SCSI\DISK&VEN_ATA&PROD_SANDISK_SDSSDH35\4&C4BDA31&0&000200 |
| \\.\PHYSICALDRIVE2 |
| X61110RL |
| NTFS |
| False |
| 465.64 GB |
| 461.11 GB |
| Microsoft |
| 10.0.22621.2506 |
| 6/21/2006 |
| 931.51 GB |
| WD-WCC6Y5YCXD59 |
| 1 |
| SCSI\DISK&VEN_ATA&PROD_WDC_WD10EZEX-75W\4&C4BDA31&0&000000 |
| \\.\PHYSICALDRIVE0 |
| 13057113 |
| NTFS |
| False |
| 931.39 GB |
| 437.04 GB |
| Microsoft |
| 10.0.22621.2506 |
| 6/21/2006 |
| 931.51 GB |
| WD-WMC1S7506981 |
| 1 |
| SCSI\DISK&VEN_ATA&PROD_WDC_WD10EZEX-60Z\4&C4BDA31&0&000100 |
| \\.\PHYSICALDRIVE1 |
| 80.00A80 |
| NTFS |
| False |
| 931.39 GB |
| 482.40 GB |
| Microsoft |
| 10.0.22621.2506 |
| 6/21/2006 |
| 476.94 GB |
| NYA3N071111803V4X _00000001. |
| 5 |
| SCSI\DISK&VEN_NVME&PROD_BC511_NVME_SK_HY\5&2DE2B5C9&0&000000 |
| \\.\PHYSICALDRIVE3 |
| 11004101 |
| NTFS |
| False |
| 455.52 GB |
| 301.96 GB |
Intel Software
Intel® Arc™ ControlVersionSizeInstall DateIntel® Killer™ Performance SuiteVersionSizeInstall DateIntel® Killer™ Performance SuiteVersionSizeInstall Date
| 1.74.5391.3 |
| 0 |
| 35.23.1292 |
| 0 |
| 35.23.1292 |
| 0 |
- Preferito
- Iscriversi
- Evidenziare
- Stampare
The duplicate message eventually cleared itself after a few hours. The problem was common to several machines. 🤷
- Contrassegnare la discussione come nuova
- Contrassegnare la discussione come letta
- Sposta questo Discussione per l'utente corrente
- Preferito
- Iscriversi
- Pagina in versione di stampa
