I have recently swapped the stock Intel Wi-Fi 6E AX211 160MHz adapter with Intel Killer Wi-Fi 7 BE1750x 320MHz adapter in my Lenovo Legion 7 Pro.
The adapter is working fine and it's showing in the Device Manager, but Intel Driver & Support Assistant and Intel System Support Utility don't detect the Wi-Fi adapter, but IDSA shows the Bluetooth as can be seen from the screenshot.
I had to install Killer Performance Driver Suite UWD to install the latest driver for the Wi-Fi and for the Bluetooth I installed the latest driver manually.
I am running Windows 11 24H2 Build 26100.1876.
UPDATE
Today IDSA was update and finally the Killer BE1750x Wi-Fi was detected.
UPDATE
