Wireless
8664 Discussions
Intel Killer wireless upgrade for vr
Omerbukru
Hello.
The motherboard I am currently using in my computer is TUF GAMING X570-PLUS (WI-FI). Wifi adapter Intel(R) Wireless-AC 9260. Can I replace it with intel killer 1675x or 1690i? Also, what is the difference between 1675x 1690i?
I want to make this change to connect to the computer with 6e while using Quest Pro.
DeividA_Intel
Hello Omerbukru,
Thank you for posting on the Intel® communities. I understand you want to know if a replacement of the current wireless card is possible.
In this case, Asus must be approved and confirm any component installed in their motherboard. Asus may have some restrictions or limitations that may cause some components not to work properly on their system.
I recommend you get in contact with Asus to confirm if any of the wireless cards mentioned are compatible and supported by your motherboard. Also, you can check the following comparison between the wireless cards you mentioned.
Deivid A.
