Wireless
8506 Discussions
Intel NUC which can work with Wi-Fi 6E AX210 6 GHz band card
Sowrirajan
I am planning to buy Intel NUC which can work for Wi-Fi 6E (6 GHz operations) in ubuntu. Can you suggest some Intel NUC which would work with Wi-Fi 6E (6 GHz card) for 6 GHz operations? A quick response would be helpful. I was thinking of 11th gen NUC TNKi7. If the existing Wi-Fi card is replaced with Wi-Fi 6E card would it work without any other changes? I am primarily looking for wi-fi packet captures in 6 GHz band.
David_G_Intel
Hello Sowrirajan
Thank you for posting on the Intel️® communities. The Intel Wi-Fi 6E AX210 is not officially supported by any of the Tiger Canyon NUCs, we recommend using the wireless card that comes integrated into the NUC. For more information about specifications please check:
David G
Linius
Hello David ,
I installed the Wi-Fi 6E AX210 in my NUC6CAY . Le device identify the card after installing the driver and i'm able to connecte to nearby wi-fi  . The issue is that after the reboot my pc can't identify the wifi card anymore . Can you help me please.
David_G_Intel
David G.
