does anyone know if the software can be silently uninstalled if so can someone provide instructions. Thanks.
Hello JGoe0,
Thank you for submitting your question on this Intel® Community.
To better assist you, we would like to have more information about your system configuration.
- Please generate a system report with the Intel® System Support Utility (Intel® SSU) and attach it to this thread.
- Intel® SSU Download link
- Open the application and click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
- Click on the menu where it says "Summary" to change to "Detailed View".
- To save your scan, click on "Next", then "Save".
- What is the Intel® PROSet/Wireless Software version you are trying to uninstall?
Wanner G.
Hello JGoe0,
We would like to provide an update.
It is not possible to uninstall the Intel® PROSet/Wireless Software silently as of today. What we can recommend is that you use a Powershell script to do so. You can also uninstall it manually on every PC.
What we have done for you is submit a new feature request. It is worth mentioning that we cannot guarantee that this request is going to be addressed.
Wanner G.
I was told it can be done by creating a uninstall package and have it pushed through SCCM. Can you confirm this is true or must it be uninstalled by the intel uninstaller. Do you have instruction you can provide to use Power shell?
Jeff Goe
Hello JGoe0,
Please allow us to look into this inquiry.
Wanner G.
Hello JGoe0,
We would like to update this thread.
- System Center Configuration Manager (SCCM)
This is a Microsoft* product. For this reason, what we can recommend is that you contact Microsoft* to obtain step-by-step instructions and receive accurate information this management suite.
- Regarding your question about PowerShell, what we can recommend is the following:
Intel usually provides instructions for a silent installation.
Support article: Silent Installation of Intel® Wi-Fi Driver 21.50.X or later for Windows* 10.
To uninstall a driver through PowerShell, in this case an Intel® PROSet/Wireless Software driver, you may need to do further research or contact a PowerShell expert to generate a script that uninstall it.
Wanner G.
