Hi
This adapter causes a bluescreen of death (BSoD) on my machine whenever I attempt Hotspot tethering with my cell phone. Error message generated is Netwtw04.sys..
On further examination of the adapter, I find the message below under Device Manager>Network Adapters>Intel(R) Dual Band Wireless-AC 7265>Events,
"Device PCI\VEN_8086&DEV_095A&SUBSYS_50908086&REV_59\B808CFFFFF07B7BC00 requires further installation."
Please help me know how I can fix this
Hello Oscar_,
1. Run the Intel® System Support Utility (Intel® SSU) and attach the report generated:
- Open the application, check the "Everything" box, and click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
- Use the paperclip icon to attach the report to the thread. Please note that only one file can be attached at a time.
2. Is this the original adapter that came pre-installed in your system? Or have you changed/installed a new adapter recently?
3. Are you having issues with Wi-Fi, Bluetooth, or both?
4. What steps do you take to reproduce this behavior?
5. Were you able to have this wireless connection in a normal/expected performance before? If yes, do you remember making any changes before the issue started?
Sebastian M.
Hello Oscar_,
Were you able to check the previous post and get the information requested? Please let me know if you need more assistance.
Sebastian M.
Hello Oscar_,
We have not heard back from you, so we will close this inquiry. If you need further assistance or if you have additional questions, please create a new thread and we will gladly assist you.
Sebastian M.
![](/skins/images/872293744008A34B36F8ABF94A46CC66/responsive_peak/images/icon_anonymous_message.png)
