Wireless
8506 Discussões
Intel(R) Wi-Fi 6 AX200 160MHz : Has encountered an internal error and has failed
WalMast
Novato
2.677 Visualizações
Like many others, I am getting frequent intermittent errors when using my 5 GHz wifi, on my Gigabyte laptop:
Intel(R) Wi-Fi 6 AX200 160MHz : Has determined that the network adapter is not functioning properly.
Intel(R) Wi-Fi 6 AX200 160MHz : Has encountered an internal error and has failed.
Error in event viewer:
<EventData>
  <Data>\Device\NDMP17</Data>
  <Data>Intel(R) Wi-Fi 6 AX200 160MHz</Data>
  <Binary>0000040002003400000000008D1300C000000000000000000000000000000000000000000000000001000000</Binary>
</EventData>
  • These problems only started after I updated my laptop to Windows 11. Everything was fine on Windows 10.
  • 2.4 Ghz WiFi connections are OK.
  • Windows says I am connected to the WiFi, but says "No internet access".
I have done a clean installation of the wireless driver - removed the device and then reinstalled intel wireless driver 23.120.0.3, but the problem persists.
Other things I have tried, to no avail:
  • Reset my network in Windows.
  • Set Random Hardware Addresses to On in the Windows WiFi settings.
1 Solução
WalMast
Novato
1.798 Visualizações
FYI, today I received an Intel WiFi driver update which seems to have fixed the problem.
Version: 23.130.1.1, Release date: April 29, 2025
This is what I was waiting for.
Ver solução na publicação original
15 Respostas
Mike_Intel
Moderador
2.624 Visualizações
Hello WalMast,
  1. What is the complete brand and model of your system?
  2. Can you share the link where did you download the driver version 23.120.0.3?
  3. Kindly check the device manager if there is an error message on the wireless controller.
  4. If there is an error, kindly share the screenshot.
Michael L.
WalMast
Novato
2.612 Visualizações
Hi Mike, thanks for replying.
It's a Gigabyte AX200NGW (GIGABYTE G5 KC) laptop.
I downloaded the driver from https://www.intel.com/content/www/us/en/download/19351/intel-wireless-wi-fi-drivers-for-windows-10-and-windows-11.html
There are no errors in Device Manager on "Intel(R) Wi-Fi 6 AX200 160MHz".
Mike_Intel
Moderador
2.557 Visualizações
Hello WalMast,
Thank you for the update.
Can you try clean driver installation method and update me if this one will help fix the issue.
Kindly refer to the link below to install the latest driver:
https://www.intel.com/content/www/us/en/support/articles/000022173/wireless.html
Michael L.
WalMast
Novato
2.529 Visualizações
I did that, and so far, so good. I'll test over a day or two and see if it maintains an internet connection on 5 GHz.
Mike_Intel
Moderador
2.500 Visualizações
Hello WalMast,
That is good to hear and I am glad that there is an improvement with your system.
Kindly observe your system and tell me if there is anything else I can help you with.
Michael L.
WalMast
Novato
2.496 Visualizações
Last night, it lost internet connection again when I moved my laptop to a room further from my modem, where I normally work. This room was always fine on 5 GHz in Windows 10. Either Windows 11 has a bug, or the Intel driver doesn't like something in Windows 11.
Also, every other wireless device works perfectly fine on 5GHz in the same room.
Mike_Intel
Moderador
2.394 Visualizações
Hello WalMast,
Let ask for the following details:
Are you still having connections issues?
Did you also check if there is no other object that between the laptop and the router?
How about the speed of the wifi?
Michael L.
WalMast
Novato
2.389 Visualizações
Yep, 5 GHz still says "No internet". Location and speed is irrelevant (yes, there are objects between laptop and router, speed is fast, 250 Mbps download), because the real issue is that it used to work on Windows 10, no longer works on Windows 11. Something about this driver on Windows 11 is not playing nicely. As I write this, I have two other devices happily on 5 GHz wifi in this same room. Only the Windows 11 laptop says "No internet" on 5 GHz.
Mike_Intel
Moderador
2.341 Visualizações
Hello WalMast,
Kindly check if the link below is the support for your laptop.
If yes, kindly download and install the latest driver from that website so that we can isolate if this is a driver issue.
https://www.gigabyte.com/eu/Laptop/G5--RTX-30-Series/support#support-dl-driver-wlan
Michael L.
WalMast
Novato
2.328 Visualizações
I tried that Gigabyte driver (it's just an older Intel driver). Problem persisted. So I went back to the latest Intel driver. Problem's still there.
I'm about to give up, blame Windows 11, and shake my fist at the continued en**bleep**tification of most IT related things.
Mike_Intel
Moderador
2.298 Visualizações
Hello WalMast,
I am really sorry to hear that.
At this point, when you say you give up. Do you still want us to proceed with this case?
Michael L.
WalMast
Novato
2.292 Visualizações
Well, if you can think of something else to try, I'd be open to it. It would be good if we could get more details about the error in the Windows event log that says an error occurred on the driver (that I posted earlier). Can more debugging or logging be enabled in the driver?
Mike_Intel
Moderador
2.203 Visualizações
Hello WalMast,
Thank you for the update,
By the way, let me also check. Have you tried contacting Gigabyte regarding this issue?
If the system was working fine with Windows 10, there is a possibility that there is a compatibility issue here. I know that the Wireless controller is from Intel, However OEM laptop manufacturers can alter, modify or enhanced these controllers and the system is controlled by their BIOS. We can only provide generic drivers, however if there is a modification in the controller, those changes are unknown to us.
Michael L.
WalMast
Novato
1.799 Visualizações
WalMast
Novato
1.686 Visualizações
Nope, spoke to soon. The driver failed again with "Intel(R) Wi-Fi 6 AX200 160MHz : Has encountered an internal error and has failed."
Responder
