Wireless
8567 Discussions
Intel(R) Wi-Fi 6 AX201 160MHz Can't see 5 GHz U-NII-3 Channels
lbrune
Hi all,
I am using an HP ProBook 650 G8 Notebook PC
OS Windows 10
with wi-fi interface
Driver Version 22.220.0.4 (Driver Date 29/03/2023)
Well my notebook can't see Wi-Fi SSID if the channel is in 5 GHz U-NII-3 band (channels 149, 153, 157, 161, 165),
in the same time my Smartphone can see the SSID.
The same notebook can see the SSID if I change the channel on the AP to bands U-NII-1 or U-NII-2
Any idea ?
thank you all
DeividA_Intel
Hello lbrune,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your Intel Wi-Fi 6 AX201.
1. Is this the original adapter that came pre-installed on your computer or did you change/install the adapter to this one?
2. Is the Bluetooth working?
3. Have you presented any issues with the 2.4 GHZ band?
4. What is the Windows 10 version and build?
5. Is this issue recent? Was the 5GHz band working before?
Deivid A.
lbrune
Hi Deivid A.
and thank you very much!
>>> Yes, it is the original
>>> Yes, it is
>>> It seems to work proprerly
OS Name: Microsoft Windows 10 Pro
Version: 10.0.19042 Build 19042
>>> I have never been able to see the 5GHz channels from 149 to 161.
I have 3 Probooks (2 with Win 10 PRO and 1 with Win 11 PRO) with the Intel Wi-Fi 6 AX201 and I have the same result.
More notes:
please consider the Notebook can use Wi-Fi 5GHz SSID in channels from 36 to 144
but the Notebook can't see 5GHz SSID channels from 149 to 161
Thank you
DeividA_Intel
Hello lbrune,
Thanks for your response. I would like you to try the following:
1. Update your Windows 10 version and build.
2. Try a clean installation of Intel drivers:
3. Try the "Recommended Settings for 802.11ax ":
4. Try to check with the laptop manufacturer to confirm if there are any restrictions with specific channels.
Deivid A.
lbrune
Hi Deivid_A,
Please can you confirm that the Intel(R) Wi-Fi 6 AX201 160MHz supports the  U-NII-3 band, channels 149, 153, 157, 161, 165.
Can you share the datasheet where I can find the supported wi-fi channels?
Does the Intel(R) Wi-Fi 6 AX201 160MHz work on other brand laptop?
Thank you
3Fees
Windows 11 supports Wifi 6 best.
You can find what Wifi channels your card supports by downloading a wifi channel scanner app and look thru the gui for visable channels, Channel 36 is usually best for Intel wifi 6
The Intel AX201 wifi card is not dependent on laptop maker or desktop maker its dependent on the socket and chipset. AX201 wifi card uses a Intel proprietary socket with only select Intel chipsets.
Anyway good luck on quest for beginners knowledge.
Cheers
3Fees
DeividA_Intel
Hello lbrune,
Thank you for the information provided
Deivid A.
DeividA_Intel
Hello lbrune,
Thanks for your patience. Based on the investigation, the channels are operated or regulated by country, and depending on the manufacturer of the laptop, the adapter may present some restrictions and is not related to drivers or configuration.
I recommend you check with the laptop manufacturer to confirm if your system is compatible with specific channels.
Please keep in mind that this thread will no longer be monitored by Intel.
Deivid A.
lbrune
Hi DeividA,
thank you for your support.
Well I will check my Laptop.
But Please can you confirm that the Intel(R) Wi-Fi 6 AX201 160MHz supports the  U-NII-3 band, channels 149, 153, 157, 161, 165
regardless of the Laptop and the country regulation.
Or is there anybody in the world who can see SSID in Channels 149, 153, 157, 161, 165 using a Intel(R) Wi-Fi 6 AX201 160MHz (with any kind of laptop).
Thank you
DeividA_Intel
Hello lbrune,
Thanks for the confirmation. I will continue with the investigation in order to provide you with further details, as soon as I get any information I will get back to you.
Deivid A.
DeividA_Intel
Hello lbrune,
Thanks for your time. Based on the investigation perform I can confirm that our network adapters support the Wi-Fi alliance and FCC standards for channels.
If you have any other questions, just let me know.
Deivid A.
DeividA_Intel
Hello lbrune,
After checking your thread, I would like to know if you need further assistance.
If so, please let me know.
Deivid A.
DeividA_Intel
Hello lbrune,
I was checking your thread and see that we have not heard back from you.
I’m going to close your post, but if you need further assistance, please do not hesitate to create a new thread.
Deivid A.
lbrune
Hi Deivid A. ,
Ok,
It could be interesting if somebody could share his system (Notebook, OS, firmware version) to understand in which cases the Intel(R) Wi-Fi 6 AX201 160MHz works.
But for the moment you can close the case.
