Wireless
8899 Discussions
Intel(R) Wi-Fi 6E AX211 160MHz Netwtw14 cannot be found.
netwtw14
I have been searching for a solution to this issue for quite a while and cannot find a definitive answer to the problem. During gaming or just general internet use, the network will drop for a second or two causing what ever I am doing to suddenly disconnect. Event viewer shows "The description for Event ID 6062 from source Netwtw14 cannot be found.". I have attempted to update/downgrade my wifi driver which hasn't worked, attempted to change the driver properties (802.11 settings) hasn't worked, and looked inside of system32 just to see if the file is missing which I can confirm that it is missing. Is there a solution to this problem or is it something that intel still needs to fix.
Ekpap
I am having this same issue on a brand new Surface Laptop Studio 2 - tried resetting and am getting the same problem.
For me the errors occurs when using Discord and Parsec, and it the error will fully disconnect me from both programs.
Been trying to fix this for a week, and suggestions as for solutions would be greatly appreciated.
I've tried all the conventional solutions:
Re-install drivers
reset
Changing wifi settings
Changing power management settings...
Any help would be greatly appreciated.
Wile_E_Coyote
Same issue here on a Dell XPS 9520.
Fresh system, all drivers up to date.
