Wireless
8693 Discussions
Intel(R) WiFi 6 AX201 160MHz device not working (code 10/43)
ErdemB
I know there are countless threads on this but none of the solutions work for me.
I have an Asus TUF Gaming F15 with 11th Gen Intel(R) Core(TM) i5-11400H @ 2.70GHz 2.69 GHz and Windows 10 Home 22H2.
I bought the laptop September 2023 in Turkey and I had no problems connecting to the network. I went to Italy and this problem started appearing. The only solution the (temporarily) worked was using CMD and inputting netcfg -d. After restarting the laptop it would work until I started gaming and the problem would reappear. I then went to another country, where I live, and it worked without any problems. Have been since to Italy few times without major issues until it reappeared again (always in Italy) and while gaming. All the solutions that were suggested were tried by me but to no avail. What is the solution?
Mike_Intel
Hello ErdemB,
  1. Was it working fine before?
  2. Did you change any settings before the issue started?
  3. What are the troubleshooting steps that you tried so far?
  4. Did you upgrade the wireless controller of your system or this is the original embedded wireless controller?
Michael L.
Mike_Intel
Hello ErdemB,
Michael L.
Mike_Intel
Hello ErdemB,
I am sending another follow up on the information that I requested.
Michael L.
