Hi, my network adaptor keeps on needing to be reset in order to connect to internet.
This was pre-installed in the PC and a possible update has been made automatically.
How do I fix it? I have attached the SSU file generated. I read another person having the same problem but the solution might be unique to individuals.
Hi Luigi011,
I understand that the Intel Wi-Fi 6 AX201 has stopped working. Please allow me to further assist you with this.
First, I would like to set your expectations by saying that I am going to ask a series of questions to narrow down the recommendations I could provide. If you may, kindly share the following details below:
- For the record, when did the issue start?
- Just to confirm, are you using the Original Equipment Manufacturer (OEM) driver version?
- What frequency are you using to connect to your access point?
- Aside from resetting the network. Have you done any other troubleshooting? If so, please specify.
- What is your router/modem model?
I will be waiting for your response.
Brian T.
Hi Luigi011,
Just a follow-up: I see that there's no movement on this thread. With that in mind, I would like to know if you wish to be supported.
Brian T.
Hello Luigi011,
Brian T.
