Wireless
9000 Discussions
Intel(R) Wireless-AC 9260 160Mhz Error Code 3
Chase5
Good Evening,
I've recently run into a issues where my computer will not allow and wifi to my computer. I currently run my computer off of Ethernet and have been for the past three years since I have built it. Due to having guest at my house I need to have people stay in my office, therefore I needed to move my computer to my room where there is not ethernet. After powering on my PC I wasn't even given the option to connect via wifi. After further review I went into my "Device Manager" tab and saw that there was a error code. I will attach a photo to give a visual representation of what I see. I've also tried uninstalling the driver and rebooting the PC and I still get the same error. I also have tried manually updating that driver as well and I still have the same issue.
Jean_Intel
Hello Chase5,
This error code is present when the operating system detects some problems with the driver. Usually, it indicates that the driver is corrupted, as the error code states. I will suggest you try a clean installation of the latest Intel drive. Follow the steps given below:
• Download and save the driver (https://www.intel.com/content/www/us/en/download/19351/windows-10-and-windows-11-wi-fi-drivers-for-intel-wireless-adapters.html)
• Disconnect the unit to the internet.
• Uninstall the Wi-Fi driver.
1. Go to Device Manager.
2. Expand the Network Adapters category.
3. Right-click your Intel Wireless Adapter and choose to uninstall it.
4. Make sure the option to Delete the driver software for this device is selected.
5. Repeat steps A through D until the option to Delete the driver software for this device is greyed out.
• Restart your computer.
• Install the driver downloaded before
Locate the driver you downloaded. Right-click the file you downloaded, then select the option to Run as administrator.
Jean O.
Jean_Intel
Hello Chase5,
I hope you are doing fine.
I have not heard back from you. So we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
