- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Please I need help when connecting to the 5G network, the speed is very bad for my laptop lenovo legion y 540
I would like an excellent solution
The network card Intel(R) Wireless-AC 9560 160MHz
コピーされたリンク
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello samooo,
In order to find what could be possibly causing this behavior, I would need to gather the following information from you:
- Please provide the model of your router.
- What is your operating system and its build?
- What is the driver that is currently installed?
- Do you experience this slow connection only when connected to 5Ghz band? Or this also occurs in 2.4Ghz?
- Have you tried connecting to a different network? If so, do you notice any improvement?
Additionally, I would appreciate if you would could run the following tool and attach the reports generated.
Intel® System Support Utility (Intel® SSU) Download link
1. Open the application and click on "Scan" to see the system and device information.
2. By default, Intel® SSU will take you to the "Summary View".
3. Click on the menu where it says "Summary" to change to "Detailed View".
4. To save your scan, click on "Next", then "Save".
Esteban D.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
- What is your operating system and its build? windows 10 64b
- What is the driver that is currently installed? Intel(R) Wireless-AC 9560 160MHz
- Do you experience this slow connection only when connected to 5Ghz band? Or this also occurs in 2.4Ghz? only 5Ghz
- Have you tried connecting to a different network? If so, do you notice any improvement? yes
- i tried connecting to a different network but no improvement
Esteban D.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello samooo,
Thank you for your response.
- Are other devices experiencing this slow connection? Or this only occurs with your laptop?
- What is the expected speed for your connection? And what is the current speed that you get?
- Please confirm your router's model.
After checking your report I noticed that you are working with the latest Intel generic drivers. As your computer is a laptop, I would strongly recommend to check with your computer manufacturer in order to download the software that is fully validated to work with your system and ensure top performance and compatibility.
This is because system manufacturers regularly customize Intel generic drivers
to meet the needs of their specific system design.
You can find the appropriate drivers for your computer here.
Additionally please check the Recommended Settings for 802.11ac Connectivity
Esteban D.
Links to third-party sites and references to third-party trademarks are provided for convenience and illustrative purposes only. Unless explicitly stated, Intel® is not responsible for the contents of such links, and no third-party endorsement of Intel or any of its products is implied.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Considering the revelations regarding Microsoft's responsibility for wireless connectivity issues (see: https://www.bleepingcomputer.com/news/microsoft/windows-10-kb4577063-update-fixes-internet-connectiv...), I would install the latest updates and then test again.
Just saying,
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello samooo,
only occurs with my laptop
- What is the expected speed for your connection? 200MB
- And what is the current speed that you get? 40MB
- Please confirm your router's model. DZS-ZIND 2428 B1
Esteban D.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello samooo,
Were you able to check the recommended the Recommended Settings for 802.11ac Connectivity
Additionally, did you tried the drivers provided by your computer manufacturer? If so, did you notice any improvement?
Please let us know what the outcome is.
Esteban D.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello samooo,
yes Has been verified the recommended the Recommended Settings for 802.11ac Connectivity
Additionally, did you tried the drivers provided by your computer manufacturer? yes
If so, did you notice any improvement? There is no improvement
Esteban D.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello samooo,
- Do you recall if this behavior occurred after the upgrade of Windows*? Or any other update?
- Do you remember if the device was working fine with Windows* version 1909?
As an additional recommendation, I would check with your router manufacturer to confirm that you are using the appropriate configuration and also the latest firmware update.
Have you tried checking with them?
Esteban D.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello samooo,
Yes, it occurs after Windows update. At first when i format my laptop the speed a full speed, but after few Windows updates i have realized that the speed is not the same.
I do not recall in which version was the speed at full speed, but my current version is 20H2.
As of the router i believe it's not the issue since it's giving me full speed in other devices except this laptop.
Esteban D.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello samooo,
Please let me know if you need further assistance.
Esteban D.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello samooo,
After the troubleshooting steps performed and as the issue was triggered due to the upgrade of the OS, we would strongly recommend checking with your Operating System Support in order to report this behavior.
As previously shared by n_scott_pearson, the new release of Microsoft* definitely has an impact in Wireless connectivity.
As a workaround I would strongly recommend rolling back to the OS build that was working as expected or going back to a restore point? For that, please contact Microsoft for guidance.
We hope that you are able to resolve this behavior after that.
Esteban D.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello samooo,
Were you able to check the recommendations provided in the previous post?
Esteban D.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello samooo,
We have not heard back from you.
If you need any additional information, please submit a new question as this thread will no longer being monitored
Esteban D.
