Wireless
8506 Discusiones
Intel WIFI 6E AX210 Very Weak Signal
StudyHacks
Novato
14.461 Vistas
I have the latest driver from 03-29-2023. The strongest signal I've got is 2 bars.
Reset the PC's network settings, no results. Tried older drivers, no results. Run a Windows Update check, no results.
My laptop is in the same room and it's got 5 bars signal strength with impeccable speed and performance.
20 Respuestas
StudyHacks
Novato
14.420 Vistas
Why haven't the Intel support techs replied to this thread yet??? Absolutely infuriating.
brokenax211
Principiante
2.500 Vistas
Because it's everyone else's problem except theirs
StudyHacks
Novato
14.419 Vistas
Also since I cannot edit posts, I'll also add: My bluetooth is also based on Intel drivers and my bluetooth, too, constantly cuts out every 2-3 seconds so much so I cannot use my bluetooth wireless headsets. Again, latest drivers installed, triple-checked.
brokenax211
Principiante
2.497 Vistas
Better directly contact your motherboard manufacter oh and restart your computer oh wait make sure to update to the latest broken driver before you check if the antenna leads are properly connected inside your brand new laptop...don't forget to create a log file so long as you have an extra TB or 5 and be prepared to share so we know how many days each month of time it has cost
Hugo_Intel
Empleados
14.390 Vistas
Hello StudyHacks
Thank you for posting on the Intel Communities. I am sorry you are experiencing a low WiFi signal on your system with the Intel® Wi-Fi 6E AX210 adapter.
Please share with us the following information to better assist:
  • Is this the original adapter that came preinstalled on your system?
  • Was it working fine previously?
  • Create a log file with the Intel® System Support Utility and attach it to your response to get more information on the hardware configuration.
Hugo O.
StudyHacks
Novato
14.383 Vistas
Yes, it is
I have no point of reference as prior to 3 days ago, I had been using Ethernet ever since I got the PC.
n_scott_pearson
Superusuario
14.350 Vistas
Have you ensured that the antenna leads are properly connected to the card and that the antenna leads are not damaged? This is the case in almost every weak signal report I have seen.
Hope this helps,
StudyHacks
Novato
14.342 Vistas
Hugo_Intel
Empleados
14.307 Vistas
Hello StudyHacks
Thank you for the information, please let's try the following:
  • Based on the log file that you provided you are using the driver version 22.220.0.4. Please install and test the latest driver provided by your motherboard manufacturer which is at the moment the most optimized for your system the version will be 22.200.0.6. Do a clean installation.
  • If the issue persists, update and install the latest generic driver available on our website version 22.230.0.
  • If the issue persists update your BIOS to the latest version available on your motherboard manufacturer's website. Once updated reset the BIOS settings to defaults,
  • Once the above steps are completed, Go to Device Manager > Wireless adapters. Right Click on the Intel® Wi-Fi 6E AX210 (Gig+) > Click on properties > Go to the Advanced tab. On the advanced tab make sure the device is configured as outlined in our recommended settings page.
Hugo O.
Hugo_Intel
Empleados
14.191 Vistas
Hello StudyHacks
I hope you are doing fine.
Hugo O.
StudyHacks
Novato
14.139 Vistas
It didn't help. The problem remains
Hugo_Intel
Empleados
14.054 Vistas
Hello StudyHacks
Allow me to check this issue with our team for further steps. I will post back once we have more information for you.
Hugo O.
Hugo_Intel
Empleados
14.027 Vistas
Hello StudyHacks
Thank you for your patience. Based on the troubleshooting we have done so far and taking into consideration the behavior of your wireless adapter has not changed. The best next step is that you directly contact your motherboard manufacturer for further troubleshooting and hardware inspections as there is a possibility of a defective motherboard/wireless adapter.
Hugo O.
brokenax211
Principiante
2.507 Vistas
The ax211 that came with my Razer 18 is defective just like the ax201 that came with my Dell XPS 15 a year and a half ago.  If there were not posts everywhere about this problem with no solution maybe I would feel different but it is going to catch up from what I am seeing
Hugo_Intel
Empleados
13.929 Vistas
Hello StudyHacks
I see there are no further questions related to this topic so we will proceed to close this thread. Feel free to open a new topic if you need further assistance.
Hugo O.
Anonymous
No aplicable
13.717 Vistas
I have the same problem. It may not be a motherboard compatibility issue because I had put in another Intel WiFi adapter which was Intel AC 9260.
I replaced it with AX210. The AX210 has about 10dbm lower. It is a big difference.
Please show us the catalog base receiving sensitivity for AC 9260 and AX210.
SarderZakirHossain
Principiante
13.152 Vistas
I am facing the exactly same problem on my Intel AX210 adapter.
Please fix the issue ASAP.
Sarder Zakir Hossain
<email removed>
ilghezzi
Principiante
8.802 Vistas
I have a Dell 7770 with the same WiFi and Bluetooth adapter and the same things described above apply to me too.
compared to other notebooks I use (Dell 7730, Simatic Field PG, Panasonic CF52) the WiFi signal is lower, sometimes much lower.
even in the factory I'm using the Dell 7730 because the 7770 doesn't allow me to have a stable signal with the machines.
the same thing described above also happens for bluetooth, the mouse stops working from time to time.
to restore the bluetooth connection I have to turn bluetooth off and on again.
this thing has improved with the latest drivers but is still not at the level of the old WiFi / Bluetooth card present in the Dell 7730.
I had to install a WiFi extender at home to improve the signal on my new Dell 7770 notebook which costs 4000 euros, but I certainly can't install an extender even in the factories where I go to work.
brokenax211
Principiante
2.509 Vistas
These cards are broken! My brand new Razer Blade 18, my 2 year old Dell XPS 15 both with 200 series ax and nothing but problems. These are very expensive laptops. Why should I have to directly contact the motherboard manufacturer on my brand new $4000 Razer Blade 18 laptop with ax211 when a little less than 2 years ago my brand new $2000 Dell XPS 15 with the ax201 had the exact problem and still does to this day which is a defective network card. thousands of problem posts all over the place and just pass the buck. I will never buy again
brokenax211
Principiante
2.500 Vistas
I personally got burned twice and twice only... as I look down at 1 bar of signal my ax211 produces sitting 10 feet from my router.
My built to order customers that have been growing with the changes I made won't
Responder
