Wireless
8563 Discussions
Intel® Wi-Fi 6 AX200 160MHz weak signal and bluetooth
BigRizoid
Hi I have a problem with really weak wifi signal and limited bluetooth connectivity
from my wireless
These are my computer specs, I have all the latest drivers from the Intel Driver and support assistant I have had to get a wireless dongle due to how weak the signal is? please help
SPECS
PC Specialist LTD Vortex ST-S
Intel® Core™ i7-10700 CPU @ 2.90GHz
ASUSTeK COMPUTER INC.
Model
PRIME B460-PLUS
David_G_Intel
Hello BigRizoid
Thank you for posting on the Intel️® communities. Please share with us the following information:
  • Do you have any issues with a specific Bluetooth device?
  • When did it start to happen?
  • Do you remember if this issue happened after a new OS update or Wireless driver update?
  • Is this issue happening at home, office environment or both?
  • Is this a new computer? If so, have check with your system's OEM for validated drivers or support on known issues related to the symptoms experienced?
  • What OS version are you using?
  • Is this the original adapter that came pre-installed in your system or have you changed/installed a new adapter recently?
  • Have you checked if this issue happens on different networks?
  • What steps do you take to reproduce your issue?
  • Were you able to have you wireless connection in a normal/expected performance before?
  • Have you installed any recent software or hardware in your system?
  • Have tried a roll back to a previous driver version for testing?
  • Have you rebooted your access-point, router, modem?
  • Which driver versions did you try already?
  • Intel® System Support Utility (Intel® SSU) results
    • Download the Intel SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows
    • Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
    • Click on the menu where it says "Summary" to change to "Detailed View".
    • To save your scan, click on "Next", then "Save".
David G
David_G_Intel
David G.
David_G_Intel
David G.
