- Contrassegnare come Nuovo
- Preferito
- Iscriversi
- Disattiva notifiche
- Iscriversi a feed RSS
- Evidenziare
- Stampare
- Segnalare contenuto inappropriato
Hello, I'm having issues with my wifi adapter after many years of use. Back in may I started seeing my wifi connection disconnect then reconnect randomly. Lasts about a few seconds in between disconnect and reconnect. All my drivers and windows is up-to-date and I previously made a post on here about it assuming it solved my issue but after a while it's still happening. At first I checked to see that it was "6062 - Lso was triggered." But after being told this was normal, I was left to think what else could these disconnects be caused. After digging more of my pc event logs, i came across the actual event id, it's "7021 - Connection telemetry fields and analysis usage." I've tried many trouble shooting on my settings, pc, and my wifi modem itself and no luck. I wanted to ask again just incase to see if i can get a different response after finding the actual event log.
Link copiato
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Hello el5,
- Are you using a desktop or a laptop?
- Is it working fine before?
- Did you change any settings before the issue started?
- What is the complete model of your system?
Michael L.
- Preferito
- Iscriversi
- Evidenziare
- Stampare
1. Desktop
2. Worked fine ever since I've built my pc over two years ago and no issues until back in may of this year where I saw random disconnects and haven't stopped.
3. First thing I did after building pc was to optimize my network settings. I have good internet and wanted to take advantage of the performance. But after optimizing my settings, I have not touched my network settings ever since.
4. I'm assuming you're asking me about my motherboard which is ASUS PRIME B550M-A (WI-FI) and using windows 11 OS.
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Hello el5,
Thank you for the quick reply.
Let me clarify some details about your update:
- Please confirm is the AX200 is onboard or embedded on your motherboard?
- What are the troubleshooting steps that you tried so far?
- Can you share screenshot of the device manager for this wireless controller if there is an error?
- Please help generate the SSU logs of your system. Kindly follow the steps in the link below:
Michael L.
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Hello el5,
Michael L.
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Hello mike,
Sorry for late reply but I upgraded my wifi modem and I no longer disconnect anymore. Waited a few days of testing to see if the problem persisted but didn't. I believe I no longer need help.
Thanks!
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Hello el5,
Thank you for the update and I am glad that the connection is now working.
Since the issue is fixed, I need to close this inquiry.
Michael L.
- Contrassegnare la discussione come nuova
- Contrassegnare la discussione come letta
- Sposta questo Discussione per l'utente corrente
- Preferito
- Iscriversi
- Pagina in versione di stampa
