Wireless
7886 Discussions
Intel Wifi 6 AX201 160Mhz Low Speed Problem
AhmetN
I own a lenovo e15 notebook. There is a Intel Wifi 6 AX201 160Mhz model wifi card on this device. However, there is a driver problem with this card.
I request that this driver be fixed.
Wifi version: 22.250.1.2
The problem is generally slowness
Please fix this.
While different device at the same point is 20Mib/s wirelessly, it is 2.4Mib/s with ax201
Jocelyn_Intel
Hello, @AhmetN
Thank you for posting on the Intel® communities. I will gladly assist you here.
I understand your frustration about getting low speeds, however, please be aware that the speeds not only depend on the driver, it depends on many factors, such as the network, the system configuration, router settings, etc.
Please, answer these questions to have a better perspective on this issue:
  1. Is the Intel® Wi-Fi 6 AX201 the pre-installed Wi-Fi card in your system or is it an integration (upgrade/ not the original card)?
  2. Does the issue happen with another network/router?
  3. Was it working before?
  4. What is the specific model of your laptop?
Jocelyn M.
Jocelyn_Intel
Hello, @AhmetN
I hope you are great.
I am checking this thread and I would like to know if you were able to check my previous post.
Jocelyn M.
Jocelyn_Intel
Hello, @AhmetN
I hope you are doing great.
As we have not heard back from you, we will proceed to close this thread now.
If you need any further assistance, please feel free to contact us back and submit a new question as this thread will no longer be monitored.
Jocelyn M.
