Wireless
8659 Discussions
Intel Wireless-AC 9260 netwtw08 driver crashes with large upload traffic
AGunn
I'm running into an issue where a large amount of upload traffic causes the netwtw08 driver for the wireless card to crash and restart. On my system, it's easily reproducible by copying a large file to a SMB share on the local network. The driver usually crashes after around 10GB of data transferred.
I've included the environment/hardware information and error messages from the event log below. I've also attached the report from Intel System Support Utility as well as the report from the "netsh wlan show wlanreport" command.
Environment:
  • Laptop: Dell XPS 9560
  • OS: Freshly installed Windows 10 1803 (Build 17134.112)
  • BIOS: 1.11.0
  • Wireless card: Intel Wireless-AC 9260
  • Wireless driver and version: Netwtw08.sys version 20.80.0.5
  • Wireless APs: 2x Ubiquiti Unifi UAP-AC-HD running firmware 3.9.54.9373
Event log:
  • Information 10/21/2018 5:27:38 PM Netwtw08 7003 None - 7003 - Roam Complete
  • Information 10/21/2018 5:33:27 PM Netwtw08 7021 None - 7021 - Connection telemetry fields and analysis usage
  • Information 10/21/2018 5:36:29 PM Netwtw08 7003 None - 7003 - Roam Complete
  • Information 10/21/2018 5:37:58 PM Netwtw08 7017 None - 7017 - secure boot (SB) configuration
  • Error 10/21/2018 5:37:58 PM Netwtw08 5000 None - Intel(R) Wireless-AC 9260 : Has encountered a conflict in resources and could not load.
  • Error 10/21/2018 5:37:58 PM Netwtw08 5002 None - Intel(R) Wireless-AC 9260 : Has determined that the network adapter is not functioning properly.
  • Error 10/21/2018 5:37:58 PM Netwtw08 5005 None - Intel(R) Wireless-AC 9260 : Has encountered an internal error and has failed.
  • Information 10/21/2018 5:38:44 PM Netwtw08 7021 None - 7021 - Connection telemetry fields and analysis usage
AGunn
I'd also like to point out this issue does not occur if I use an Intel Wireless-AC 8265 in the same laptop.
Hello chenxiaolong,
Thank you for posting on the Intel ® communities.
I can see that you are having problems with an Intel ® wireless adapter when transferring big amounts of data.
Regarding this, I would like to begin by mentioning that you need to first get in contact with your manufacturer before upgrading or changing the wireless adapter. More information about this can be found here:
https://www.intel.com/content/www/us/en/support/articles/000005687/network-and-i-o/wireless-networking.html https://www.intel.com/content/www/us/en/support/articles/000005687/network-and-i-o/wireless-networking.html
What was the original wireless adapter? If the original one does not give problems but the one you installed does then it means that it could be a software/hardware incompatibility which is why we recommend to get in contact with the manufacturer before any change or upgrade.
David V
Under Contract to Intel Corporation
Hello chenxiaolong,
I am following up with your case and see that we have not heard back from you.
If you need more assistance do not hesitate to reply.
David V
