About 5 months ago, my laptop stopped showing the wifi connections box in the bottom right tray. I have tried many things to fix it including:
- multiple full windows reinstalls (resets)
- updating driver using Ethernet
- uninstalling the driver and restarting
- uninstalling driver and installing another one
- network resets
- windows troubleshoot (it detects the problem but doesn't do anything)
- uninstalling oem13.inf and Netwtw08 using CMD and reinstalling the driver
- disabling all non-windows startup processes and restarting
- disabling all windows security features and restarting
Sometimes when I try a fix, it will work for a few minutes or a few days, then it will go back to not working.
I am getting a Code 10 on the Wireless driver and events, it says device PCI\VVEN_8086&DEV_A370&SUBSYS_02A48086&REV_10\3&11583659&1&A3 had a problem starting and also that the driver name is oem13.inf. Sometimes it says oem50.inf or oem31.inf
Only things I haven't tried are updating Bios or downgrading to Windows 10. I have a suspicion it has to do with windows 11, but I can't downgrade from settings (thanks Bill Gates).
I think I attached what you might need (the SSU scan).
Any help is greatly appreciated
PS I doubt its hardware related. I've never dropped my laptop and it connected fine to wifi multiple times before not working again.
You may find all the drivers for your computer on the OEM Site. For example this link for Bluetooth Driver and this for a WiFi Driver.
Since you did full reset for your system, I suggest to install the Chipset Software and reboot your computer, before installing any other driver.
Leon
Performing clean installation (i.e. uninstalling the currently installed drivers) may be better, however, you may try to install the OEM drivers over the currently installed. Only if the installation fails, uninstall the drivers.
Leon
Any ideas help thanks.
Hhmmm, I wonder if Windows Update is installing an older version over top of the newer one. Start the process again and, when it fails, look to see whether the version number of the driver has changed.
