Wireless
8607 Discussions
Intel Wireless-AC 9560 160Mhz Выбранный диапазон сети недоступен Хот-спот 5ГГц При выборе диапазона частоты 5 Ггц и запуска хот спот выскакивает сверху ошибка красными буквами "Выбранный диапазон сети недоступен. Выберите..."
zh3rtwa
версия драйвера wi fi Intel Wireless-AC 9560 160Mhz 21.80.2.1
материнская плата z390 aorus master
процессор i7 8700k
оперативная память crucial 2400 16 Gb
Windows 10 1909 последней версии.
AndrewG_Intel
Hello zh3rtwa
We would like to inform you that our support is only provided in English. We may not be able to translate screenshots attached to the thread. To better assist you, we use a translation tool embedded in this Intel Community.
In order to check this inquiry further, could you please confirm the following information?
1- Please elaborate more on the issue you are experiencing and the steps you are following.
2- Are you trying to enable your system as a Mobile Hotspot and share your Internet using the Wi-Fi and the 5GHz band? Does it work if you use the 2.4GHz band?
3- Also, country-specific regulatory limitations may affect the functionality and availability of Windows® 10 Mobile Hotspot capabilities. Could you please confirm through a private message only the country where you are located?
4- Is the Intel® Wireless-AC 9560 the original wireless adapter that came pre-installed in your system or did you install it on the laptop?
Andrew G.
zh3rtwa
  1. In the mobile hot spot, wireless Internet does not turn on when you select a 5 GHz network range.
  2. Yes, I want to share the Internet using wi fi and the 5 GHz band. wi fi works on the 2.4 band, when you select the 5 GHz band, wi fi does not turn on and a red message pops up from above: "The selected network range is not available. Select a different range and try again."
  3. Russia
  4. The wi fi module itself was built-in at the time of purchase, in the z390 aorus master motherboard. When drivers are installed, the system identifies it as Intel® Wireless-AC 9560
AndrewG_Intel
Hello zh3rtwa
Thank you very much for all the details provided.
Based on the information you provided where you mentioned that you are in Russia, this is expected behavior due to country-specific regulatory limitations.
You may get an error or not see the 5 GHz band option in certain situations.
Regulatory limitations exist in certain countries (for example, as of 2018, Russia, Japan, China, Israel, Indonesia, and so on) where hotspot isn't allowed to operate on the 5GHz band by itself. You can only use the hotspot on 5GHz when the Windows® 10 PC is connected to a wireless Access Point (AP) operating on specific (passive) 5GHz channels at the same time.
However, you may use hotspot on 5GHz by connecting to an Access Point (AP) on the approved 5GHz (passive) channels for the country before initializing the hotspot. Please contact your AP manufacturer to check if those approved (passive) channels are supported and for instructions on how to set the proper settings.
For more information, please refer to Using Windows® 10 Mobile Hotspot on 5 GHz Band.
Andrew G.
zh3rtwa
Nothing is clear, but it was interesting))
AndrewG_Intel
Hello zh3rtwa
Thank you for your response.
We understand that this might not be the answer you were looking for. However, based on country-specific regulatory limitations, what we can recommend is checking with the Acess Point/Router manufacturer if it would be possible to apply the fix described in the link provided in our previous post:  Using Windows® 10 Mobile Hotspot on 5 GHz Band.
Andrew G.
zh3rtwa
The method that does not work in the link.
AndrewG_Intel
Hello zh3rtwa
The possible fix described in the link we shared for the issue of getting an error or not seeing the 5 GHz band option depends upon Access Point (AP) capabilities (connecting to an AP on the approved 5GHz (passive) channels).
Unfortunately, this is regulated by your country's laws and related to country-specific regulatory limitations. If the AP does not have the option for the fix, our last suggestion is to check this further with your Original Equipment Manufacturer (OEM) of the motherboard, in this case, GIGABYTE* support team.
Andrew G.
Links to third-party sites and references to third-party trademarks are provided for convenience and illustrative purposes only. Unless explicitly stated, Intel® is not responsible for the contents of such links, and no third party endorsement of Intel® or any of its products is implied.
