Wireless
8606 Discussions
Intel Wireless AC 9560 no longer detected after changing to kernel 5.4.0-150 on Ubuntu 18.04
Priesemut
With kernel version 5.4.0-149 the Intel Wireless AC 9560 in my ThinkPad P1 running Ubuntu 18.04 is working fine, but with kernel version 5.4.0-150 the card is no longer detected, i.e.
lspci | grep wifi gives no output.
Strange enough, modinfo iwlwifi also gives no output and sudo modprobe iwlwifi throws an error message that this module would not be know.
I have backports-iwlwifi-dkms installed.
I checked /lib/firmware to ensure the presence of the corresponding files.
Intel's Linux support is usually quite good, this is likely to be a operating system issue.
Which additional diagnostics could I run to pin down the problem?
Mike_Intel
Hello Priesemut,
For us to further check this, please help provide the following details:
  1. Can you share the link of the driver used?
  2. Have you checked with Lenovo if the system supports Ubuntu 18.04?
  3. Is there an error message? Can you share some screenshots
Michael L.
Mike_Intel
Hello Priesemut,
Michael L.
Mike_Intel
Hello Priesemut,
I am sending another follow up on the information that I requested.
Michael L.
