Wireless
8846 Discussions
Intel chipset AX201 does NOT support UNI3 channels !
WiFision
I have found on many laptops with an Intel chipset AX201 that windows 10/11 does NOT support UNI3 channels. If I test the same Laptop with Ubuntu (then the UNI3 channels are recognized and supported).
I have tested this with Windows 10 (20h2 / 21h2) and latest windows 11 (22.160.0.4/22.170.0.3) in the Netherlands (REGION)
With this I proved that the AX201 hardware does support it. The problem is not solved even in the latest Windows software version (22.170.0.3)
I cannot connect to a wireless network if the UNI3 channels are not supported in Windows. So I can NOT provide logs  (Intel iWFT tool) I would like to get in direct contact with Intel Wi-Fi developers.
With there existing testing process  I can't convince the Intel Customer Support and i have shared a wireshark capture !
CASE 05604856 (started 9th september 2022)
In the Netherlands, the UNI3 channels were released a long time ago....
UNI3 (5 GHz : 149, 153, 157, 161 & 165)
WiFision
Support ,
Please pay attention to this ticket. Support has been unresponsive for 2 weeks. I am completely ignored. What is going on ?
