Hi everybody,
I have upgraded to windows 10 but since then there is a problem with the internet. Sometimes it works while sometimes it doesn't.
Sometimes it shows that NO CONNECTIONS ARE AVAILABLE and when I troubleshoot, it says that there might be a problem with the driver. My wireless adapter is intel® centrino® wireless-n 2230 and I am unable to find its driver for windows 10. Kindly help.
Hello jagjeet,
Windows 10* provides its inbox drivers for the intel® centrino® wireless-n 2230. If you are experiencing any inconvenience with your connection, our first recommendation would to contact your computer manufacturer and see if they have any available solution that might help you resolve the issue. In the meantime, you are welcome to try one of our solutions available. Please check the links below.
http://www.intel.com/support/wireless/sb/CS-030709.htm?wapkw=wifi+recommended+settings Recommended Settings for 802.11n Connectivity
http://www.intel.com/support/wireless/wlan/sb/CS-034658.htm Intel® Wi-Fi Products - Quick Checks That Might Improve or Fix Connection Issues
http://www.intel.com/support/wireless/wlan/sb/CS-025332.htm Intel® Wi-Fi Products — Resolving Wi-Fi Network Connection Issues
http://www.intel.com/support/wireless/wlan/sb/CS-031509.htm Intel® Wi-Fi Products — Possible Interference by Other Wireless Devices May Impact 802.11n Performance
http://www.intel.com/support/wireless/wlan/sb/CS-006321.htm Intel® Wi-Fi Products — Access Point (AP) Firmware Updates May Resolve Wireless Network Issues
http://www.intel.com/support/wireless/wlan/sb/CS-031641.htm Intel® Wi-Fi Products — Which Operating Systems Are Supported by Intel Wireless Products?
http://www.intel.com/support/wireless/sb/CS-029893.htm Wireless Networking — Frequently Asked Questions - Wi-Fi
http://www.intel.com/support/wireless/wlan/sb/CS-035591.htm Intel® Wi-Fi Products — Current Top 10 Frequently Asked Questions
Hello jagjeet,
Thanks for the answer.
My laptop is Dell inspiron-15R- 5530 and dell does not support this device for windows 10. However I have fixed the issue myself by changing the Driver power management settings. I have disabled the feature which permits the computer to turn off the device to save power. This fixed half of the problem. Then I changed my Power Plan Settings from Power Saver to High performance and since then my internet is working fine. So it is possible be that in Windows 10 there might be a problem with the Power Management which Microsoft has not fixed yet.
Once again thanks for your help.
Jagjeet,
Thank you for letting us know it. We are glad to know all is working fine now.
