Wireless
8608 Discusiones
Killer Performance Suite v3.1121.1159 interrupted
Vinny5353
Principiante
7.388 Vistas
When I try and install the Killer Performance Suite v3.1121.1159 it says "The wizard was interrupted before Killer Performance Driver Suite UWD could be completely installed." Please help me fix this error.
0 kudos
1 Solución
Matty_P
Principiante
7.314 Vistas
(Update : I have found a way to fix it)
When installing the new driver I custom picked what I want installed (Disabled the other drivers 3xxx and it fixed it the issue for me. And only installed 2xxx version)  So try installing only your version and unchecking the rest.
I am having the exact same issue.
  • What is the model of the killer card? : Killer E2600 Gigabit Ethernet Controller & Killer(R) Wi-Fi 6 AX1650i 160MHz Wireless Network Adapter (201NGW)
  • Is this a laptop or a desktop system? Laptop
  • What operating system version are you using? Windows 11 Home Edition
  • Does this happen with only that version? Yes (The last version 3.1121.1048) Is working fine when I installed it. (3.1121.1159) is having issues.
  • Please share a screenshot of the error.
Ver la solución en mensaje original publicado
13 Respuestas
donb2022
Principiante
7.369 Vistas
Same here also, hope there's a way to solve this?
David_G_Intel
Moderador
7.328 Vistas
Hello @Vinny5353
Thank you for posting on the Intel️® communities. Please share with us the following information:
David G
donb2022
Principiante
7.323 Vistas
1.) What is the model of the killer card?
      Killer E3000 2.5 Gigabit Ethernet Controller
2.) Is this a laptop or a desktop system?
      Desktop
3.) What operating system version are you using?
      Windows 11 Pro (updated from Windows 10)
4.) Does this happen with only that version?
      I'm guessing yes, since I've never ran into this problem.
5.) Please share a screenshot of the error.
Matty_P
Principiante
7.315 Vistas
A_Skiba
Principiante
7.304 Vistas
I have encountered the same issue.
Through trial and error, using the custom install I tried installing every driver package and they all installed successfully on their own and along side the others, except for the 3100 drivers. The 3100 drivers where the only ones resulting in an installation error when selected either on their own or along side any combination of the other drivers.
The rest of the drivers were installed without any problems both alone and with each other, and this has also updated my Intel Driver & Support Assistant to show my drivers and software are up to date.
Killer® Wi-Fi 6 AX1650i 160MHz Wireless Network Adapter (201NGW)
Killer E3100G 2.5 Gigabit Ethernet Controller
Laptop
Microsoft Windows 11 Home (64-bit)
Version (Build): 21H2 (10.0.22000)
Yes, tried the previous version (3.1121.1048) and it worked with no issue.
The screenshot would display the exact same thing as the others.
Vinny5353
Principiante
7.272 Vistas
      Desktop
      Windows 11 Home
     I don't know, I am guessing yes.
David_G_Intel
Moderador
7.285 Vistas
Thank you for the feedback. We will investigate this and post the updates on the thread.
David G
David_G_Intel
Moderador
7.197 Vistas
Thank you all for the visibility. In this case, the recommendation for this issue is to perform a custom installation as some of the users have mentioned before, keep the necessary drivers and disable the ones that are not for your system. Also please confirm if that workaround works for you @Vinny5353
David G
donb2022
Principiante
7.169 Vistas
Yep, doing the custom installation worked for me.
David_G_Intel
Moderador
7.116 Vistas
Thank you for the update, we will continue working on this.
David G
David_G_Intel
Moderador
7.006 Vistas
Hello @Vinny5353
Can you please confirm if that workaround works for you?
David G
David_G_Intel
Moderador
6.988 Vistas
David G.
David_G_Intel
Moderador
6.965 Vistas
Before we close the case, please use the latest driver on the Intel® Killer™ Performance Suite released on the Jan 14th that comes with the fix.
David G
Responder
