Wireless
9030 Discussions
Killer Performance Suite
olegeezer
The new Killer Performance Suite Version: 36.25.2193 has a gliche in it. See the screenshot.
That keeps it from installing onto Windows 11.
Thanks, Matt
Mike_Intel
Hello olegeezer,
  1. What is the model of your wireless controller?
  2. What is the brand and model of your system/motherboard?
  3. Do you already have an existing Killer Performance Suite installed?
  4. What are the troubleshooting steps that you tried so far?
Michael L.
olegeezer
The gliche has been corrected.   have the intel Killer BE200/1750xw wifi card. My laptop is Asus ROG Stryx GL703GM i7 8750H with Windows11 Home 64bit version 24H2. I have 36.25.2193 Killer Performance Suite installed  and it passes the compatibility test by Windows.
Yet there are no controls I can use to select my network or bandwidth or anything else on the control panel. I have watched youtube videos of 36.25.2193 showing control buttons being used but they are nowhere to be found on my 36.25.2193 control panel screen.
The only thing I can do is turn on and off things like Prioritization, Smart AP, Set Bandwidth, etc but can do nothing else.
I have removed every trace of Killer Performance Suite from my laptop and done a clean install more than once but nothing changes.
Thanks, Matt
olegeezer
My ethernet controllers are Realtek driver version 10.26.328.2018.  Latest available version.
Thanks, Matt
MEGAmasterking
I'm having the same problem (probably). I can't install the new drivers that the Intel driver assistant proposed.
Have you found a way to install them?
