Wireless
8547 Discussions
Killer internet dropping connection and reconnecting on Acer predator helios 300
jemsei
I have Killer(R) Wi-Fi 6 AX1650i 160MHz Wireless Network Adaptor (201NGW) on my Acer Predator Helios 300 (PH315-53). My internet will drop randomly and reconnect after a couple of seconds, which will happen at any time of the day. I feel like I have tried everything and am hoping someone on here has a solution to this issue.
Steven_Intel
Hello jemsei,
In order to better assist you, please provide the following information:
  • When did the issue start? Was there any hardware change or any driver/OS update before the issue started?
  • What troubleshooting steps have you performed so far?
  • Is this the original adapter that came pre-installed in your system, or have you changed/installed a new adapter recently?
Steven G.
jemsei
Hey, thanks for replying. I think this started a couple of months ago, and I have not had any other issues than this. This should be the same adapter. I have tried unchecking the “allow this computer to turn this off to save power” I have restarted the network adapter, deleted it and automatically reinstalled the default, changing options for the adapter in advanced and updating drivers and installing updated killer performance suites.
Steven_Intel
Thank you for your response.
Please provide the following information:
Open the application and select "Everything", click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View". Click on the menu where it says "Summary" to change to "Detailed View". To save your scan, click on "Next", then "Save". Please attach the file to your reply.
Steven G.
Steven_Intel
Steven G.
Steven_Intel
Since we have not heard back from you, we will close this thread. If you need any additional information, please submit a new question, as this thread will no longer be monitored.
Steven G.
