Wireless
8537 讨论
Killer performance suite fail installation error code 1603
LAPARAMOR
新手
31,640 次查看
novice here...error code 1603!
标签 (1)
0 项奖励
51 回复数
Steven_Intel
主持人
21,015 次查看
Hello LAPARAMOR,
I am sorry you are having issues with the Killer Performance Suite, I will be glad to assist.
Please download the Intel® SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
Open the application and select "Everything", click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View". Click on the menu where it says "Summary" to change to "Detailed View". To save your scan, click on "Next", then "Save". Please attach the file to your reply.
Steven G.
0 项奖励
LAPARAMOR
新手
20,959 次查看
Hello Steven_Intel,        I don't know how to attach the file to my reply.  Will ask someone for help..THANK YOU for your response...
0 项奖励
LAPARAMOR
新手
20,903 次查看
Hello Steve...file in reply...I hope!...THANKS
0 项奖励
LAPARAMOR
新手
20,887 次查看
Hi Steve....
0 项奖励
kdawg
初学者
16,395 次查看
Hi Steven any help would be appreciated.
0 项奖励
DanaMSteiner
初学者
15,027 次查看
I need help as well, same error code. Here is save from my pc
0 项奖励
VincePura
初学者
14,625 次查看
Hi steven! file in reply!
Help would be appreciated!
0 项奖励
R0NTS4
初学者
13,670 次查看
Hello Steven
0 项奖励
Thiem
初学者
8,585 次查看
0 项奖励
ScottWrobel
初学者
3,366 次查看
Steven,
I just joined the channel and am encountering the same issue.  I turned off my virus software and tried to install the update but still get the error.  I downloaded the scan software and am attaching the results text file.  Can you check my setup and let me know what is causing the error?  Thanks.
0 项奖励
VinceP1
初学者
3,341 次查看
I fixed using Microsoft troubleshooter tool, do a search on killer suite fix using tool, don't remember where I found instructions, it's article I'd is 000058907.
0 项奖励
YivanArchi
初学者
2,044 次查看
Same issue Steven, thanks in advance!
0 项奖励
Steven_Intel
主持人
20,938 次查看
I appreciate your response.
After saving the SSU file, you can attach it to your reply by clicking on the Reply button, and then you can either drag and drop the file in the upload box or you can click on browse to select the file.
Steven G.
0 项奖励
Steven_Intel
主持人
20,828 次查看
Many thanks for your response.
Is the error occurring when downloading it from the Intel Driver & Support Assistant?
Please try downloading the Intel® Killer™ Performance Suite manually from the Download Center (https://www.intel.com/content/www/us/en/download/19779/intel-killer-performance-suite.html) if you have not already.
Let me know of the outcome.
Steven G.
0 项奖励
Brendt
初学者
18,815 次查看
I have the same situation above, but in my installed programs is the "Killer Ethernet Performance Driver Suite UWD" by Rivet Labs, ver. 2.4.1541.  It seems like this may be a customized version of the Intel Killer Ethernet Performance Driver.
However, it is unclear if this should be uninstalled so the new Intel Killer Suite can be installed instead. Any chance that you can clarify?
Brendt
0 项奖励
LAPARAMOR
新手
18,794 次查看
Hi BRENDT, I uninstalled the KILLER ETHERNET PERFORMANCE DRIVER SUITE UWD. I did a restart. Installed the KILLER PERFORMANCE SUITE UWD.  I did the uninstalled from the control panel...hope this is helpful....
0 项奖励
LAPARAMOR
新手
18,794 次查看
Hi BRENDT, I also had the KILLER ETHERNET PERFORMANCE DRIVER SUITE UWD in my installed programs....
0 项奖励
Steven_Intel
主持人
20,791 次查看
We would like to know if you were you able to check the previous post.
Steven G.
0 项奖励
LAPARAMOR
新手
20,729 次查看
Hello Stteven...I got the following message when downloading from the Download Center: Killer Performance Driver Suite UWD cannot be installed with Killer Ethernet Performance Suite...
0 项奖励
deNja2k
初学者
15,654 次查看
hello Steven G.
i have same problem with update
Installation failed with error code 1603)
0 项奖励
回复
