Wireless
8662 Discussions
Killer performance suite won't install (Code 2732)
Robert-S
Greetings Everyone,        I have an Alienware Aurora R11 desktop computer with Killer E3000 2.5 Gigabit Ethernet Controller. For quite some time I have been getting Message update from intel to install Killer Performance Suite. Every time I try to update, I get a message that says, "Killer Performance Driver Suite UWD cannot be installed with Killer Wireless Drivers" (Code 2732). As I am a novice, I am looking for any advice on how I can fix this issue. I can give more info, if needed.        Any help would be greatly appreciated and Thank You in advance. I wasn't sure where exactly I should post this. I hope I wasn't too far off.
JosueO_Intel
Hello Robert-S,
Thank you for posting on the Intel communities. In order to have a better understanding of the issue, please share with us the following information:
  1. Where do you see the update message?
  2. Have you tried using the drivers provided by the OEM?
  3. Is this the original adapter of the system?
  4. Screenshot of the issue.
Also, please download and install the Intel System Support Utility (Intel SSU):
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel SSU will take you to the "Summary View". Click on the menu where it says "Summary" to change to "Detailed View".
Click on "Next", save the report and attach it to your response.
Josue O.
JosueO_Intel
Hello Robert-S,
Josue O.
JosueO_Intel
Hello Robert-S,
Josue O.
juliot315
Hello, I am getting this error when trying the Killer performance suite. (Intel driver support assist is flagging me to update.)
Error: 2732 Director Manager not initiated.
I followed tech directions to remove my current killer driver and tried to install the suite but with no luck. I had to recover the drive to get things back online.
I have attached a screenshot of the current killer driver I am using. It is from an MSI Raider GE 68 HX 14VGG laptop.
Any help would be appreciated.
