Wireless
8506 Discussões
Konfigurieren von festen Känale bei Intel Link 5300 Wifi MiniPCIe Karte
Funcionário
1.296 Visualizações
Hallo!
In Europa können meines Wissens im 802.11b,g Standard die Kanäle 1 bis 13 benutzt werden. Wieviele Kanäle können bei der Intel Link 5300 MiniPCIe Karte z.B .im 802.11b,g, Modus eingestellt werden? Ich kann hiezu im Treiber nichts finden und würde gerne einen festen Kanal einstellen.
Ich konnte auch bei der beigelegten CD, die nur die alten Treiber v12 ... hat, nichts finden.
Karte: Intel® Ultimate N WiFi Link 5300 / Model Code: 533AN_MMW
Treiber (von der Intel-Seite) : z.B. für Win7_x32_v13.4
Danke vorab für gute Infos
Ralf
2 Respostas
Ilene_K_Intel
Funcionário
615 Visualizações
Hi Ralf,
In order to access channels 12 and 13, you must have an adapter that supports these channels. The ability to access the channels is not based on your software version.The Intel® WiFi Link 5300 does support these channels. There is some information at http://www.intel.com/support/wireless/wlan/sb/CS-006064.htm http://www.intel.com/support/wireless/wlan/sb/CS-006064.htm that should be helpful. Since the adapter uses passive scanning for channels 12 and 13 it may take longer to connect to the wireless router.
Ilenek
Intel Customer Support
Funcionário
615 Visualizações
Hi Ilenek,
thanks for your answer. Do you know if there exists a driver for the WiFi Card*) supporting Channel 12 and 13? The card would be build in IPCs for the European market.
Is it possible to use one fixed channel only? For example channel 4. How can I do this?
*) Intel® Ultimate N WiFi Link 5300 / Model Code 533AN_MMW
Best Regards
Ralf
Responder
