Wireless
9014 Discussions
Langsames Internet
ChrisSchla
Hallo,
ich habe ein Intel Dual wireless AC 8260. Leider ist seid einiger zeit das Internet sehr schlecht und das obwohl eine 100k Leitung vorhanden ist. Die Durchschnittliche Leistung liegt bei 300kbits bis 1,2mbits ... Habe die Treiber Aktualisiert und Manuell auch Reinstalliert aber es gibt keine Verbesserung. Für Lösungsvorschläge wäre ich sehr dankbar.
Grüße
Jean_Intel
Hello ChrisSchla,
Our support is only provided in English. We may not be able to translate the screenshots attached to the thread. To better assist you, we use a translation tool, hence; the translation may not be completely accurate.
  • When did it start to happen?
  • Were you able to have your wireless connection in a normal/expected performance before?
  • Do you remember if this issue happened after a new OS update or Wireless driver update?
  • Does the issue persist when using other networks?
  • Are you able to reproduce the same issue while on a hardwired connection?
  • Is this the original adapter that came pre-installed in your system or have you changed/installed a new adapter recently?
Jean O.
Jean_Intel
Hello ChrisSchla,
I hope you are doing fine.
Jean O.
Jean_Intel
Hello ChrisSchla,
I have not heard back from you. So I will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
