I´m looking for the latest driver for the Intel dual band wireless-n 7260 for Windows 10 64bit. The official support pages are not available (404). It would be very nice if anyone could tell me a download link. (f.e. url )
Thanks and best regards,
Christian
Use this link: https://1drv.ms/f/s!AtacZBU04mo-j-tQ34BdSDv6y1BFsg?e=7gn50T to access my archive. Subfolders provide final driver packages for most of the Discontinued Wireless adapters.
Hope this helps,
I also need the win 64 drivers for the AC7260
@fll,
Hope this helps,
OMG, People: turn off threaded display!
Hope this helps,
OMG, Again! People: turn off threaded display!
Hope this helps,
I'll take a copy.
What causes this to quit working, is it a windows update?
@69TransAm and @GrumpyOG,
As for the 'what' question, there was an incompatibility between the WiFi4/WiFi5 7260 and 3160 adapters with WiFi6+ routers. Intel introduced a fix for this issue in the final driver release provided before support for these adapters was dropped.
Hope this helps,
Thanks. Being the anxious/impatient guy that I am I downloaded the drivers from Intel, 3 sets - Bluetooth, Wireless, and IT Admin..
I followed your instructions and 'removed the hell' out of everything listed (including using CCCleaner), rebooted an extra time, installed Bluetooth first, then installed the Wireless drivers. I have WiFi for the first time in 3 years!!
Muchos Gracias.
Here's the link for the latest driver...
https://www.dell.com/support/home/en-us/drivers/driversdetails?driverid=400ff
My problem was that the wi-fi 6 wasn't showing at all, after the update to 18.33.17.1 everything went fine!
On my Dell Inspiron 7437 the only way to install was the EXTRACT option and update driver trough Windows Device Manager, select the Wireless Adapter, Properties, Driver and Search for driver in the extracted folder
Thats it!
Use this link: https://1drv.ms/f/s!AtacZBU04mo-j-tQ34BdSDv6y1BFsg?e=7gn50T in order to access my archive. Subfolders provide final driver packages for most of the Discontinued Wireless adapters.
Hope this helps,
Hope this helps,
No, I'm sorry, but I can't send them to you. The files are simply too large to be emailed and too large to be uploaded to the Forum. There are many hundreds of people who have successfully accessed and downloaded the files. I am not sure what your issue is, but can look into it if you explain exactly what is going on.
So I figured out the issue I'm not able to save multiple files at once had to select each one and save each one separate so it was my issue which i solved after i sent that, but thank you for the reply and thank you for hosting the files.
Hope this helps,
Hi Scott
Sir, I'm wholeheartedly grateful to you for posting legacy Intel drivers archives. I had exhausted nearly all means to obtain these drivers without which my expensive Dell precision workstations had almost become obsolete - even though their robust hardware is fully serviceable. This act of your kindness is highly appreciated. Thank you indeed.
hello is there a new driver mine says from 2015 and keeps dropping connection then saying no driver installed
The final driver releases for the 3160, 7260 and 7265-C silicon/cards was released in May of 2019. The package version was 21.10.1. The Wireless driver version was 18.33.17.1. The Bluetooth driver version was 20.100.5.1.
Since these are (long) discontinued silicon/cards, Intel is no longer hosting the driver packages for download. Luckily, I saw the discontinuation coming and saved away the package files in my own archive. Until a better home is found, I have placed this portion of this archive into my OneDrive share. Use this link: https://1drv.ms/f/s!AtacZBU04mo-j-tQ34BdSDv6y1BFsg?e=7gn50T to access the public portion of my archive. Subfolders provide final driver packages for most of the Discontinued Wireless adapters.
Hope this helps,
Hope this helps,
P.S. Sigh! I am getting sick of having to repeat this same post over and over and over and over. Look around in the conversation - and especially at the latest posts! Actually, this is the fault of the site itself, which makes threaded display the default. Choose Linear!
Hope this helps,
Привіт,
Я шукаю найновіший драйвер для Intel dual band wireless-AC 7260 для Windows 11 64bit. Офіційні сторінки підтримки недоступні (404). Було б дуже добре, якби хтось міг сказати мені посилання для завантаження.
Дякую і всього найкращого,
Чех2019
