Wireless
8781 Discussions
Max clients on wifi access point with 7265
MPANN1
I use a https://www.intel.fr/content/www/fr/fr/products/wireless/wireless-products/dual-band-wireless-ac-7265.html Intel Dual Band Wireless-N 7265 on a https://www.intel.fr/content/www/fr/fr/products/boards-kits/nuc/kits/nuc5cpyh.html Intel NUC NUC5CPYH. The OS is Linux Debian 8.
I create an access point with HostAPD in b/g/n mode.
Do you know the limit of the number of users connected at the same time on the wifi? Works fine with 14 connected devices but not more
How to increase it?
This limit is hardware?
I can't find information about this.
MPANN1
iw list
Wiphy phy0
max # scan SSIDs: 20
max scan IEs length: 393 bytes
Retry short limit: 7
Retry long limit: 4
Coverage class: 0 (up to 0m)
Device supports RSN-IBSS.
Device supports AP-side u-APSD.
Supported Ciphers:
* CCMP (00-0f-ac:4)
* TKIP (00-0f-ac:2)
* WEP40 (00-0f-ac:1)
* WEP104 (00-0f-ac:5)
* CMAC (00-0f-ac:6)
* WPI-SMS4 (00-14-72:1)
Available Antennas: TX 0 RX 0
Supported interface modes:
* IBSS
* managed
* AP
* AP/VLAN
* monitor
* P2P-client
* P2P-GO
* P2P-device
Band 1:
Capabilities: 0x11e2
HT20/HT40
Static SM Power Save
RX HT20 SGI
RX HT40 SGI
TX STBC
RX STBC 1-stream
Max AMSDU length: 3839 bytes
DSSS/CCK HT40
Maximum RX AMPDU length 65535 bytes (exponent: 0x003)
Minimum RX AMPDU time spacing: 4 usec (0x05)
HT TX/RX MCS rate indexes supported: 0-15, 32
Bitrates (non-HT):
* 1.0 Mbps
* 2.0 Mbps (short preamble supported)
* 5.5 Mbps (short preamble supported)
* 11.0 Mbps (short preamble supported)
* 6.0 Mbps
* 9.0 Mbps
* 12.0 Mbps
* 18.0 Mbps
* 24.0 Mbps
* 36.0 Mbps
* 48.0 Mbps
* 54.0 Mbps
Frequencies:
* 2412 MHz [1] (20.0 dBm)
* 2417 MHz [2] (20.0 dBm)
* 2422 MHz [3] (20.0 dBm)
* 2427 MHz [4] (20.0 dBm)
* 2432 MHz [5] (20.0 dBm)
* 2437 MHz [6] (20.0 dBm)
* 2442 MHz [7] (20.0 dBm)
* 2447 MHz [8] (20.0 dBm)
* 2452 MHz [9] (20.0 dBm)
* 2457 MHz [10] (20.0 dBm)
* 2462 MHz [11] (20.0 dBm)
* 2467 MHz [12] (20.0 dBm) (no IR)
* 2472 MHz [13] (20.0 dBm) (no IR)
Band 2:
HT20/HT40
RX HT20 SGI
RX HT40 SGI
TX STBC
RX STBC 1-stream
DSSS/CCK HT40
VHT Capabilities (0x038071a0):
Max MPDU length: 3895
Supported Channel Width: neither 160 nor 80+80
short GI (80 MHz)
TX STBC
SU Beamformee
VHT RX MCS set:
1 streams: MCS 0-9
2 streams: MCS 0-9
3 streams: not supported
4 streams: not supported
5 streams: not supported
6 streams: not supported
7 streams: not supported
8 streams: not supported
VHT RX highest supported: 0 Mbps
VHT TX MCS set:
1 streams: MCS 0-9
2 streams: MCS 0-9
VHT TX highest supported: 0 Mbps
Bitrates (non-HT):
* 6.0 Mbps
* 9.0 Mbps
* 12.0 Mbps
* 18.0 Mbps
* 24.0 Mbps
* 36.0 Mbps
* 48.0 Mbps
* 54.0 Mbps
Frequencies:
* 5180 MHz [36] (20.0 dBm) (no IR)
* 5200 MHz [40] (20.0 dBm) (no IR)
* 5220 MHz [44] (20.0 dBm) (no IR)
* 5240 MHz [48] (20.0 dBm) (no IR)
* 5260 MHz [52] (20.0 dBm) (no IR, radar detection)
DFS state: usable (for 544 sec)
DFS CAC time: 60000 ms
* 5280 MHz [56] (20.0 dBm) (no IR, radar detection)
* 5300 MHz [60] (20.0 dBm) (no IR, radar detection)
* 5320 MHz [64] (20.0 dBm) (no IR, radar detection)
* 5500 MHz [100] (22.0 dBm) (no IR, radar detection)
* 5520 MHz [104] (22.0 dBm) (no IR, radar detection)
* 5540 MHz [108] (22.0 dBm) (no IR, radar detection)
* 5560 MHz [112] (22.0 dBm) (no IR, radar detection)
* 5580 MHz [116] (22.0 dBm) (no IR, radar detection)
DFS CAC time: 60000 ms</p...
Hello MikaP,
There's not an established number for the maximum number of clients that can connect to a system with an Intel® Wireless adapter when used as an access point (with HostAPD or similar applications). This is defined by other factors such as the device driver and the application itself.
The Linux* Intel® Wireless adapters are developed through the Linux* community. You may contact thehttps://wireless.wiki.kernel.org/en/users/Drivers/iwlwifi# support Linux* driver support or your https://www.debian.org/support.en.html distribution support for further assistance.
NOTE: Links to third party sites are being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
Eugenio F.
orobi
did you find the answer ? did you find a solution to extend this limit ?
I use a NUC intel which seem to be similar to yours : NUC 7i7BNH X1.
there is a chipset for wifi, integrated to the board : Intel® Wireless-AC 8265
this chipset seem to be able to go until 867 mbps.
on my side, I can connect only 8 device (ipad ) on the hotspot. I am running Ubuntu 18.04.
I need to connect 16 ipads...
the wifi is extremely slow, less than 50 mbps : the NUC is not connected on internet.
the ipad are far away less than 2 meter from the NUC !
any idea , any infos about your problem could, may be, help me.
many thanks for any advice.
Best regards.
Olivier
MPANN1
Yes, i found a solution. Don't use the intern Wifi 😏 ! The limit is near 12 connexions only; after 12, the hotspot doesn't work correctly. It's not a software problem but hardware.
The easly solution is to have another Wifi module as the "ASUS USB-N14" (< 30$) , i can connect more 40 device (IPad) without problem 😄
orobi
ok, I see.
thanks for feedback.
on my side, I need to have fast wifi, so I will look for something like the Asus N300, nut faster ( I would need more than 867 mbps if possible)
I tried to buy the tp-link archer T9UH, but it seem to not be able to create an access point, or a hotspot.
Thanks for your help.
Best regards
Olivier
