I bought a NUC13RNGI90001, and am really displeased to find that no Linux distro supports the built-in Intel Wi-Fi interface. I have tried the following distros and kernels without success:
- Debian Sid, kernel 6.1.0
- Fedora, kernel 6.2.9
- Ubuntu, kernel 6.2.0
- Gentoo, kernel 6.1.19
- Arch, kernel 6.2.8
`lspci` shows:
00:14.3 Network controller: Intel Corporation Alder Lake-S PCH CNVi WiFi (rev 11)
Subsystem: Rivet Networks Alder Lake-S PCH CNVi WiFi
Flags: fast devsel, IRQ 18, IOMMU group 6
Memory at 604c124000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [c8] Power Management version 3
Capabilities: [d0] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [40] Express Root Complex Integrated Endpoint, MSI 00
Capabilities: [80] MSI-X: Enable- Count=16 Masked-
Capabilities: [100] Latency Tolerance Reporting
Capabilities: [164] Vendor Specific Information: ID=0010 Rev=0 Len=014 <?>
Kernel modules: iwlwifi
And `dmesg` shows:
[ 6.986553] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[ 6.988469] iwlwifi: No config found for PCI dev 7af0/1692, rev=0x430, rfid=0x3010d000
[ 6.988479] iwlwifi: probe of 0000:00:14.3 failed with error -22
From this post and this post, I see that it's simply that Intel has not updated their driver code to include the PCI ID properly and that's all that's needed. I have followed those steps, but unfortunately it still did not solve the problem in my case.
More information from my system:
- Installed Linux originally, never Windows
- Fastboot is disabled in the BIOS
`uname -a`:
Linux yottabit-NUC13RNGi9 6.2.0-20-generic #20-Ubuntu SMP PREEMPT_DYNAMIC Thu Apr 6 07:48:48 UTC 2023 x86_64 x86_64 x86_64 GNU/Linux
`rfkill list`:
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
`modinfo iwlwifi`: large file, see attachment.
`lsmod | grep iwlwifi`:
iwlwifi 569344 0
cfg80211 1241088 1 iwlwifi
`lshw -C network`:
*-network UNCLAIMED
description: Network controller
product: Alder Lake-S PCH CNVi WiFi
vendor: Intel Corporation
physical id: 14.3
bus info: pci@0000:00:14.3
version: 11
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix cap_list
configuration: latency=0
resources: iomemory:600-5ff memory:604c124000-604c127fff
*-network
description: Ethernet interface
product: Aquantia Corp.
vendor: Aquantia Corp.
physical id: 0
bus info: pci@0000:02:00.0
logical name: enp2s0
version: 03
serial: 48:21:0b:51:90:43
capacity: 10Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix bus_master cap_list rom ethernet physical tp 10bt-fd 100bt-fd 1000bt-fd 10000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=atlantic driverversion=6.2.0-20-generic firmware=1.3.24 latency=0 link=no multicast=yes port=twisted pair
resources: irq:16 memory:92800000-9287ffff memory:928a0000-928a0fff memory:92400000-927fffff memory:92880000-9289ffff
*-network
product: Ethernet Controller I226-V
physical id: 0
bus info: pci@0000:03:00.0
logical name: enp3s0
version: 04
serial: 48:21:0b:51:90:42
capacity: 1Gbit/s
width: 32 bits
clock: 33MHz
capabilities: pm msi msix pciexpress bus_master cap_list rom ethernet physical 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=igc driverversion=6.2.0-20-generic duplex=full firmware=2017:888d ip=172.16.42.146 latency=0 link=yes multicast=yes port=
twisted pair speed=1Gbit/s
resources: irq:18 memory:92a00000-92afffff memory:92b00000-92b03fff memory:92900000-929fffff
When may I expect this be implemented? Will it be backported into older kernels? This is ridiculously poor support from Intel for their latest top-of-the-line NUC model.
Hello yottabit
We noticed this is a duplicate thread of your other thread with the title NUC 13 Extreme Wi-Fi Support for Linux PLEASE. Please continue posting on the original thread, in order to prevent duplicate topics this thread will be closed and no longer monitored.
Hugo O.
