Wireless
8908 Discussions
Need driver
FLang5
I have a Dell Inspiron 1545 with Windows Vista 32 Bit. Where do I get the driver for Intel Centrino Ultimate-N 6300 wireless card A/B/G/N
CJuli3
I have replaced the DDR4 and HDD with no effect. I have changed parameters i BIOS. I´m very querious about this error. Is it a flaw in the NUC design or some other weakness? It wouldn´t suprise me if not more users will get the same problem. It is a pity that then WHEA appears directly at the boot process the NUC shuts down directly without indicating what error it have detected. It seems to store it in some kind of a log. But what´s the point when you can't access it.
Sous le choc, Tris et Quatre doivent fuir et franchir le mur encerclant Chicago. Pour la première fois, ils quittent la seule ville et famille qu'ils aient connues.
http://divergente3-audeladumur.posthaven.com/ http://divergente3-audeladumur.posthaven.com Mais au delà du mur se trouve un monde hostile qu'ils vont devoir affronter.
As the situation is now the only way to access the NUC is through MS-DOS.
ASouz7
sbrandywyne,
Unfortunately, the support for Windows* Vista has been discontinued and there are no drivers available.
