Wireless
8515 Discussions
Need drivers for wifi 6 AX201 (11 generation hardware) for Parrot os linux
BugHunter
Bought a new laptop with configuration:
CPU: 11th Gen Intel i7-1165G7 (8) @ 4.700GHz
Kernel: 5.14.0-9parrot1-amd64
OS: Parrot OS 5.0 (LTS) x86_64
Host: HP ProBook 450 G8 Notebook PC
My wifi ( Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi) is not working with internal Wifi card and working with an external adapter it is not damaged (works with windows 11) and I am stuck with this for 2 months.
OTHER QUESTIONS:
Is Bluetooth working? > Yes it is working fine.
Does Wifi stopped after any update? > No, It did’nt work since I installed linux.
TERMINAL OUTPUTS:
sudo modinfo iwlwifi
filename: /lib/modules/5.14.0-9parrot1-amd64/kernel/drivers/net/wireless/intel/iwlwifi/iwlwifi.ko
license: GPL
author: Intel Corporation linuxwifi@intel.com
description: Intel(R) Wireless WiFi driver for Linux
firmware: iwlwifi-100-5.ucode
firmware: iwlwifi-1000-5.ucode
firmware: iwlwifi-135-6.ucode
and so many other files list
sudo dmesg | grep iwlwifi
Very long List
sudo dmesg | grep ASSERT
[ 5839.393084] iwlwifi 0000:00:14.3: 0x201002FF | ADVANCED_SYSASSERT
[ 5840.127172] iwlwifi 0000:00:14.3: 0x201002FF | ADVANCED_SYSASSERT
[ 5840.317880] iwlwifi 0000:00:14.3: 0x201002FF | ADVANCED_SYSASSERT
[ 5841.509222] iwlwifi 0000:00:14.3: 0x201002FF | ADVANCED_SYSASSERT
[ 5842.325477] iwlwifi 0000:00:14.3: 0x201002FF | ADVANCED_SYSASSERT
[ 5842.516446] iwlwifi 0000:00:14.3: 0x201002FF | ADVANCED_SYSASSERT
[ 5843.789616] iwlwifi 0000:00:14.3: 0x201002FF | ADVANCED_SYSASSERT
[ 5844.644453] iwlwifi 0000:00:14.3: 0x201002FF | ADVANCED_SYSASSERT
[ 5844.837702] iwlwifi 0000:00:14.3: 0x201002FF | ADVANCED_SYSASSERT
[ 5846.208709] iwlwifi 0000:00:14.3: 0x201002FF | ADVANCED_SYSASSERT
[ 5847.035788] iwlwifi 0000:00:14.3: 0x201002FF | ADVANCED_SYSASSERT
[ 5847.228445] iwlwifi 0000:00:14.3: 0x201002FF | ADVANCED_SYSASSERT
[ 5848.468514] iwlwifi 0000:00:14.3: 0x201002FF | ADVANCED_SYSASSERT
[ 5849.216785] iwlwifi 0000:00:14.3: 0x201002FF | ADVANCED_SYSASSERT
[ 5849.409404] iwlwifi 0000:00:14.3: 0x201002FF | ADVANCED_SYSASSERT
[ 5850.644810] iwlwifi 0000:00:14.3: 0x201002FF | ADVANCED_SYSASSERT
sudo lshw -C network
*-network UNCLAIMED
description: Network controller
product: Wi-Fi 6 AX201
vendor: Intel Corporation
physical id: 14.3
bus info: pci@0000:00:14.3
version: 20
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix bus_master cap_list
configuration: latency=0
resources: iomemory:600-5ff memory:600324c000-600324ffff
*-network
description: Ethernet interface
product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:02:00.0
logical name: eth0
version: 15
serial: 48:9e:bd:51:4c:c8
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8168 driverversion=8.048.03-NAPI latency=0 link=no multicast=yes port=twisted pair
resources: irq:145 ioport:3000(size=256) memory:54004000-54004fff memory:54000000-54003fff
*-network
description: Wireless interface
physical id: 2
bus info: usb@3:6
logical name: wlan0
serial: 1c:bf:ce:79:b9:b5
capabilities: ethernet physical wireless
configuration: broadcast=yes driver=mt7601u driverversion=5.14.0-9parrot1-amd64 firmware=N/A ip=192.168.10.12 link=yes multicast=yes wireless=IEEE 802.11
What I tried Before:
Updating Firmware from Here but no use
  • I updated my firmware by downloading and copying this to /lib/firmware but wifi still not working
Searching Wifi in Bios:
  • It is working in bios
Copying Wifi 6 AX201 drivers from here and paste in /lib/firmware
  • I downloaded these drivers and pasted in /lib/firmware (even all .ucode file were there but I replaced them) but no use
Pressing F3 for Third party ROM Management and wifi was working and connected there via card AX201
As you can see WiFi is connected:
NOTE: Wifi is not working on Fedora Live, Ubuntu Live and nor on Kali and Parrot is my main Issue
WHAT SHOULD I DO NOW???
Jean_Intel
Hello @BugHunter
Your issue seems to be related to the OS or drivers creating a conflict with the AX201 adapter, as the adapter runs as expected when using Windows 11. For any Driver related matters on Linux OS, they are available through the distributions or the Linux Kernel archives.
My suggestion is to be in contact with the support for your Linux distribution to confirm if they have any drivers available for this specific wireless module.
I hope you find this information helpful.
Jean O.
Jean_Intel
Hello @BugHunter
I hope you are doing fine.
Jean O.
Jean_Intel
Hello BugHunter
We hope you are doing fine.
We have not heard back from you. So we will close this thread, if you need any additional information, please submit a new question as this thread will no longer be monitored.
Best regards.
Jean O.
