Wireless
8982 Discussions
Network connection
vxceegmveegvi
I reinstalled windows 10 yesterday via recovery
After that something is wrong with wifi adapter, the entire internet speed is normal but only the download speed is kinda limited and unstable
It doesn't even go up to 1Mbps
I have done most of tips found on internet like dns server but nothing fixed it
Please help
David_G_Intel
Hello vxceegmveegvi
Thank you for posting on the Intel️® communities. Please share more information with us:
  • Do you get any Bluetooth issues?
  • Is this a laptop or desktop system?
  • Is this issue happening at home, office environment or both?
  • Is this a new computer? If so, have check with your system's OEM for validated drivers or support on known issues related to the symptoms experienced?
  • What OS version are you using?
  • What adapter model do you have?
  • Is this the original adapter that came pre-installed in your system or have you changed/installed a new adapter recently?
  • Have you checked if this issue happens on different networks?
  • Are you able to reproduce the same issue while on hardwired connection?
  • How do you measure the speeds?
  • Were you able to have you wireless connection in a normal/expected performance before?
  • Have tried a roll back to a previous driver version for testing?
  • Have you rebooted your access-point, router, modem?
David G
David_G_Intel
Please also include the Intel® System Support Utility (Intel® SSU) results
David G
David_G_Intel
David G.
David_G_Intel
David G.
