- Отметить как новое
- Закладка
- Подписаться
- Отключить
- Подписка на RSS-канал
- Выделить
- Печать
- Сообщить о недопустимом содержимом
I have a rather strange problem on 2 identical laptops with the Dualband Wireless AC7265 adapter installed on Windows 10
The newest drivers are installed and also the newest Windows 10 version but the problem was there before that as well.
The laptops are connected to a domain network and everything looks normal.
When connected to the wifi network:
Internet works
gpupdate /force is generating errors and will not load.
When I go to network in windows explorer it says that the folder is empty.
When I type the name of my fileserver in the address it will find it and connect to it.
When I am connected to the ethernet adapter everything works:
Gpupdate /force works
When I go to network in windows explorer all my network printers etc. are shown.
Clearly this is something in the wireless intel adapter.
Any help is appreciated
Ссылка скопирована
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello itsrunning,
We understand you're having issues updating your group policy using the Intel® Dual Band Wireless-AC 7265 in Windows® 10.
In order to better assist you, we would like to have the the following information:
1. Please share the exact gpupdate /force error message, or a screenshot of it.
2. Please clear your Group Policy event logs, reproduce the issue, then export these logs.
1. Event Viewer > Applications and Services Logs > Microsoft* > Windows* > GroupPolicy > Operational
3. Please download and run the https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility Intel® System Support Utility on one of these computers (or both). Run the scan selecting "Everything." Save this report and upload.
To enable attachments, make sure to select the option to "use advanced editor" while replying.
We look forward to hearing back from you.
Carlos A.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi Carlos,
I am on a trip at the moment and will be back next week. I will do what you asked then and come back to you.
Is that ok?
Cyril
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello Cyril,
That's perfectly ok. We'll take a look at the information once you're able to provide it.
Carlos A.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello Larissa,
Just to make sure we get all the details correct:
- Are you also able to update using Ethernet but not wireless?
- Do you have any other system which do allow you to update your group policy via wireless?
Carlos A.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello Cyril, Larissa,
We haven't heard back from you in a while.
Has the issue been resolved?
Carlos A.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi Carlos,
No not yet been resolved. I have sent log files and other items to the intel tech department by their request today. They are looking into it at the moment.
If I hear something back from them I will let you know
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello Cyril,
Hadn't realized that you engaged your local Intel® support. We'll look up the case and will make sure to follow that one as well.
Once you're able to resolve the issue, please feel free to share any helpful info with the community.
Carlos A.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi Carlos,
This is the casenumber: Case # : 03082558 [ ref:_00DU0YT3c._5000PdgeqV:ref ]
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
I'm able to use ethernet and other devices work fine on the wifi network.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello Larissa,
Please provide us the following:
1. Please share a screenshot of the gpupdate /force error message.
3. You report that other machines don't have the same issue, which wireless adapters do these computer have?
4. What is the brand and model of your wireless access points?
5. Where you able to update your group policy via wireless with the Intel® adapters before (using an older or OEM driver version, for example)?
Carlos A.
- Отметить тему как новую
- Отметить тему как прочитанную
- Выполнить отслеживание данной Тема для текущего пользователя
- Закладка
- Подписаться
- Страница в формате печати
