Wireless
8525 Discussões
Not getting any speed after getting connected to 5G network. I am using Intel(R) Wi-Fi 6E AX driver.
Gitish
Principiante
1.927 Visualizações
I am using Intel(R) Wi-Fi 6E AX211 160MHz driver. When i connect to 4G network (2.4Ghz) it gives me 80mbps speed without any issue. But when i connect to 5G network (5Ghz) it gives me no speed. Also it keeps on disconnecting from 5G network.
My device configuration is
Motherboard- msi pro z690-a wifi ddr5
processor- i5-13600k
Windows- 11
wireless driver- Intel(R) Wi-Fi 6E AX211 160MHz
Note- On other devices i am getting more than 200mbps speed using same 5G network.
Please look into this.
6 Respostas
DeividA_Intel
Funcionário
1.893 Visualizações
Hello Gitish,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your Intel® Wi-Fi 6E AX211.
1. Is this the original adapter that came pre-installed on your computer or did you change/install the adapter to this one?
2. Is the Bluetooth working?
3. What is the brand and model name of your router/modem?
4. Are you using antennas?
5. Do you have the same issue if you connect to a different network?
6. Do you know if this issue is recent? Was it working before?
Deivid A.
Gitish
Principiante
1.870 Visualizações
Hello David, thanks for your reply. Here is more information as you requested.
I recently in January assembled my system. Windows 10 was installed first. There was no wifi driver installed then. After that I upgraded to windows 11 and a wifi driver got installed automatically. I don't remember if it was this or other. But when i upgraded my internet connection to 5G and encountered the issue I checked the driver, and the driver is same as now (Intel(R) Wi-Fi 6E AX211 160MHz). Also then, i uninstalled the driver and installed the latest available from intel site which is same (Intel(R) Wi-Fi 6E AX211 160MHz).
Yes, bluetooth is working fine.
Brand- Revo
Model- RVXPON302WAC
The motherboard has inbuilt wifi, it uses antennas.
My internet connection has two bands, one if 5G (5Ghz) and other is 4G (2.4Ghz). It works fine with 4G but no speed with 5G.
I don't have any other 5G network.
Before I was using only 4G network, and it was working well. As i upgraded my internet connection to 5G, the 5G network doesn't work on my system (working well on my other devices though). 4G is working fine as before.
Looking forward for the solution.
DeividA_Intel
Funcionário
1.823 Visualizações
Hello Gitish,
Thanks for your confirmation. In order to continue further, I would like you to try the following:
1. Install the latest driver version:
2. Test the 2.4GHz and 5GHz bands on a different network (AP/router)?
3. Run all the Windows optional updates.
4. Check with MSI to confirm if you have the latest BIOS version (7D25vAB).
Deivid A.
Gitish
Principiante
1.664 Visualizações
I have installed latest intel wireless driver, i.e. 22.220.0
I have not any other network to test (I will test it once i get any option)
I have run all the windows update
I have updated the BIOS to latest version i.e. 7D25vAB
Still i have same issue.
Let me know further solution..
DeividA_Intel
Funcionário
1.792 Visualizações
Hello Gitish,
After checking your thread, I would like to know if you need further assistance.
If so, please let me know.
Deivid A.
DeividA_Intel
Funcionário
1.742 Visualizações
Hello Gitish,
I was checking your thread and see that we have not heard back from you.
I’m going to close your post, but if you need further assistance, please do not hesitate to create a new thread.
Deivid A.
Responder
