Wireless
8787 Discussions
Obscure behavior: IP address remains reachable after WiFi network is disconnected
KiPe_NG
Dear Forum,
I am seeing a rather obscure behavior with my AX201 based WiFi, for which I wanted to ask for feedback.
Whats irritating is that, disabling the wireless card (using the Windows 11 taskbar, see [0]) the IP address that the interface got assigned during operation (via DHCP, not static) will remain reachable [1].
However, the system itself (Windows 11) is showing no traces of this IP. Not assigned to a network adapter or anywhere else!?! [1]. Also, it was verified that the system is completely offline.
This is somewhat counter intuitive. When an interface is down, has no IP address assigned, why should "anything" inside the system continue to answer to that historic IP without network connection?
Furthermore, this is obviously also not consistent as it is not aligned with the state a system is in after a fresh boot, without the respective network connected.
It is easy to reproduce this. Simply:
0. on my PC with a Intel AX201 WiFi card
1. connect system to a WiFi network
2. determine the IP (v4) address the system received (ipconfig, see [1] for example)
3. disable WiFi via Windows (see [0])
4. ping the IP (v4) address and see "someone" respond (see [1] for an example)
5. verify no part of the system is holding this address (see ipconfig and arp in example [1])
NOTE: The effect and procedure are to be seen from "inside" the PC exposing the problem. I.e. the system is completely offline during testing, still reacting to an IP that it should only be "owning" when actually connected to a specific network.
I am running a Windows 11, on an HP Laptop with an Intel AX201, latest version Windows, all patches installed, latest version Intel drivers.
It seems that the (Intel) WiFi is not "unregistering" its IP properly (?) - or not "disabling" the adapter or tearing down the interface really?
There seems to be at least one other forum entry where a used is experiencing something similar [2].
Any thoughts on this?
Any ideas how to further debug?
[0] Windows-taskbar after Disabling WiFi:
[1] Sequence of commands on a shell to show the issue:
PS C:\Windows\System32> ipconfig /all
Windows IP Configuration
   Host Name . . . . . . . . . . . . : Laptop-[CENSORED]
   Primary Dns Suffix  . . . . . . . :
   Node Type . . . . . . . . . . . . : Hybrid
   IP Routing Enabled. . . . . . . . : No
   WINS Proxy Enabled. . . . . . . . : No
   DNS Suffix Search List. . . . . . : fritz.box
Unknown adapter Local Area Connection:
   Media State . . . . . . . . . . . : Media disconnected
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : TAP-Windows Adapter V9 for OpenVPN Connect
   Physical Address. . . . . . . . . : 00-FF-[PRIVATE]
   DHCP Enabled. . . . . . . . . . . : No
   Autoconfiguration Enabled . . . . : Yes
Unknown adapter OpenVPN Connect DCO Adapter:
   Description . . . . . . . . . . . : OpenVPN Data Channel Offload
   DHCP Enabled. . . . . . . . . . . : Yes
Wireless LAN adapter Local Area Connection* 3:
   Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #4
   Physical Address. . . . . . . . . : 54-14-[PRIVATE]
Wireless LAN adapter Local Area Connection* 13:
   Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #5
   Physical Address. . . . . . . . . : 56-14-[PRIVATE]
Mobile Broadband adapter Cellular:
   Description . . . . . . . . . . . : Generic Mobile Broadband Adapter
   Physical Address. . . . . . . . . : 84-9B-[PRIVATE]
Wireless LAN adapter Wi-Fi:
   Connection-specific DNS Suffix  . : fritz.box
   Description . . . . . . . . . . . : Intel(R) Wi-Fi 6 AX201 160MHz
   IPv6 Address. . . . . . . . . . . : 2a02:[PRIVATE](Preferred)
   Lease Obtained. . . . . . . . . . : Sonntag, 1. September 2024 13:41:58
   Lease Expires . . . . . . . . . . : Sonntag, 1. September 2024 15:23:22
   IPv6 Address. . . . . . . . . . . : fd0e:[PRIVATE](Preferred)
   Temporary IPv6 Address. . . . . . : 2a02:[PRIVATE](Preferred)
   Temporary IPv6 Address. . . . . . : fd0e:[PRIVATE](Preferred)
   Link-local IPv6 Address . . . . . : fe80::[PRIVATE]%7(Preferred)
   IPv4 Address. . . . . . . . . . . : 192.168.22.40(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Lease Obtained. . . . . . . . . . : Sonntag, 1. September 2024 13:41:57
   Lease Expires . . . . . . . . . . : Sonntag, 29. September 2024 13:44:15
   Default Gateway . . . . . . . . . : fe80::[PRIVATE]%7
                                       192.168.22.1
   DHCP Server . . . . . . . . . . . : 192.168.22.1
   DHCPv6 IAID . . . . . . . . . . . : 743707891
   DHCPv6 Client DUID. . . . . . . . : 00-01-[PRIVATE]
   DNS Servers . . . . . . . . . . . : fd0e:[PRIVATE]
                                       2a02:[PRIVATE]
                                       192.168.22.1
   NetBIOS over Tcpip. . . . . . . . : Disabled
PS C:\Windows\System32> ping 192.168.22.40
Pinging 192.168.22.40 with 32 bytes of data:
Reply from 192.168.22.40: bytes=32 time<1ms TTL=128
Ping statistics for 192.168.22.40:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 0ms, Maximum = 0ms, Average = 0ms
PS C:\Windows\System32> arp -g
Interface: 192.168.22.40 --- 0x7
  Internet Address      Physical Address      Type
  192.168.22.1          3c-37-[PRIVATE]     dynamic
  192.168.22.20         90-09-[PRIVATE]     dynamic
  192.168.22.32         48-9e-[PRIVATE]     dynamic
  192.168.22.114        00-22-[PRIVATE]     dynamic
  192.168.22.249        54-2a-[PRIVATE]     dynamic
  224.0.0.22            01-00-5e-00-00-16     static
  224.0.0.251           01-00-5e-00-00-fb     static
  224.0.0.252           01-00-5e-00-00-fc     static
  239.255.255.250       01-00-5e-7f-ff-fa     static
  255.255.255.255       ff-ff-ff-ff-ff-ff     static
PS C:\Windows\System32> echo "WiFi disabled via Windows Taskbar"
   Host Name . . . . . . . . . . . . : Laptop-[PRIVATE]
No ARP Entries Found.
[2] Spiceworks forum entry on the same topic:
https://community.spiceworks.com/t/getting-a-ping-when-everything-is-disconnected-why/687691/10
KiPe_NG
P.S.: Same is true for the assigned IPv6 address, where the prefix (in my case 2a02:...)  is announced by the router and really only valid if a network is connected.
