Wireless
8663 Discussions
Pinout of the Intel AX201
GDasq
I am developping a board with a PCIe Key E connector and I would like to connect to it the Wifi 6 Module Intel AX201. In order to have it works properly I need to know th pinout of the module to put the same signal on the connector.
Where can I find this information ?
Thank you,
Guilhem
David_G_Intel
Hello GDasq
Thank you for posting on the Intel️® communities.
The pinout, datasheet and other technical information can be found on Intel® Resource & Design Center (RDC) For more information please visit:
Please keep in mind that this thread will no longer be monitored by Intel. Thank you for your understanding.
David G
Intel Customer Support Technician
Zelimir96
Have you managed to find the necessary documents and implement the AX201 module on your PCB? I currently need the same information, so I hope you can help me.
Best,
Zelimir
