Wireless
8536 Discussions
Planning to use Wi-Fi Chipset WAV600 Series based module. Is there any open hardware open bugs or software open bugs release note i can refer to?
HTank1
Gala_Alfonzo
Intel’s Connected Home Division has been acquired by MaxLinear. Details on the acquisition of connected home products for Puma, Wi-Fi Access Points, Ethernet and Home Gateway SoC products can be found at www.maxlinear.com.
Alberto_R_Intel
HTank1, Thank you for posting in the Intel® Communities Support.
In reference to your question, from our side, the information that we have currently available for the Intel® Home Wi-Fi Chipset WAV600 is the product specifications and the product brief:
https://ark.intel.com/content/www/us/en/ark/products/135926/intel-home-wi-fi-chipset-wav600-series.html
https://www.intel.com/content/dam/www/public/us/en/documents/product-briefs/wi-fi-chipset-wav-600-series-brief.pdf
Is there any particular reason why you need that information?
Are you working on a project?
If that is the case, what is the project about?
Just to let you know, if you already purchased the Intel® Home Wi-Fi Chipset WAV600, you can always get in contact directly with the place of purchase to gather further details about the product, they might have reports about open hardware bugs or software open bugs release notes.
Alberto R.
A Contingent Worker at Intel
HTank1
Hi Alberto,
How should I put it?
Yes. We are working with ODM to buy a off the shelf 2x2 antenna 802.11ax solution using WAV600 with pcie x1 interface.
We are struggling to choose solution between below two:-
(1) 2x2 802.11ax solution using WAC600 pcie x1 interface
(2) AX200 module. I heard there is a limitation that only 8 client can be connected in AP mode.
As a true engineer advice, can you please put technical reason (pro vs cons) between WAC600 and AX200??? I want to go really too technical here.
Himanshu
Alberto_R_Intel
Hi HTank1, Thank you very much for providing those details.
Just to let you know, the support that we provide for these specific kinds of products is limited and it is basically for end-users.
Since you need to get really too technical with this subject, what we recommend is to visit, sign in and submit your inquiry in our Intel® Resource and Design Center, you should receive further assistance in there about this matter:
https://www.intel.com/content/www/us/en/design/resource-design-center.html
Another option is to get in contact directly with your FAE (Field Application Engineer) if you have one or to get in contact with the Intel® Authorized Distributors to request further assistant from their FAE:
https://www.intel.com/content/www/us/en/partner/where-to-buy/overview.html
Alberto R.
Gala_Alfonzo
