Please provide wifi driver for ubuntu OS.
currently throws below output in dmseg
.364685] iwlwifi 0000:03:00.0: enabling device (0000 -> 0002)
[ 3.379270] iwlwifi 0000:03:00.0: Detected crf-id 0x2001910, cnv-id 0x2001910 wfpm id 0x80000000
[ 3.379453] iwlwifi 0000:03:00.0: PCI dev 272b/00f4, rev=0x472, rfid=0x112200
[ 3.383809] iwlwifi 0000:03:00.0: Direct firmware load for iwlwifi-gl-c0-fm-c0-83.ucode failed with error -2
[ 3.383923] iwlwifi 0000:03:00.0: Direct firmware load for iwlwifi-gl-c0-fm-c0-82.ucode failed with error -2
[ 3.384100] iwlwifi 0000:03:00.0: Direct firmware load for iwlwifi-gl-c0-fm-c0-81.ucode failed with error -2
[ 3.384201] iwlwifi 0000:03:00.0: Direct firmware load for iwlwifi-gl-c0-fm-c0-80.ucode failed with error -2
[ 3.384202] iwlwifi 0000:03:00.0: no suitable firmware found!
[ 3.384214] iwlwifi 0000:03:00.0: minimum version required: iwlwifi-gl-c0-fm-c0-80
[ 3.384223] iwlwifi 0000:03:00.0: maximum version supported: iwlwifi-gl-c0-fm-c0-83
[ 3.384232] iwlwifi 0000:03:00.0: check git://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git
[ 340.974310] iwlwifi 0000:03:00.0: Detected crf-id 0x2001910, cnv-id 0x2001910 wfpm id 0x80000000
[ 340.974405] iwlwifi 0000:03:00.0: PCI dev 272b/00f4, rev=0x472, rfid=0x112200
[ 340.975185] iwlwifi 0000:03:00.0: Direct firmware load for iwlwifi-gl-c0-fm-c0-83.ucode failed with error -2
[ 340.975216] iwlwifi 0000:03:00.0: Direct firmware load for iwlwifi-gl-c0-fm-c0-82.ucode failed with error -2
[ 340.975237] iwlwifi 0000:03:00.0: Direct firmware load for iwlwifi-gl-c0-fm-c0-81.ucode failed with error -2
[ 340.975259] iwlwifi 0000:03:00.0: Direct firmware load for iwlwifi-gl-c0-fm-c0-80.ucode failed with error -2
[ 340.975262] iwlwifi 0000:03:00.0: no suitable firmware found!
[ 340.975271] iwlwifi 0000:03:00.0: minimum version required: iwlwifi-gl-c0-fm-c0-80
[ 340.975274] iwlwifi 0000:03:00.0: maximum version supported: iwlwifi-gl-c0-fm-c0-83
[ 340.975276] iwlwifi 0000:03:00.0: check git://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git
sqewlbt@sqewlbt-NUC12WSKi7:~$
Hello @AdityaM
We understand you are looking for Linux drivers for your Intel® Wi-Fi 7 BE200. But, since we noticed you have opened a Web Ticket with us and we will continue to help you through this channel now. We will therefore close this case. Thank you.”
Jose B.
![](/skins/images/7FC17B7B85029576C25F1E43CE255B51/responsive_peak/images/icon_anonymous_message.png)
